B&M Racing
Old 02-28-2013, 06:01 AM   #1
gkelsch
Drives: 2010 Camaro 2SS
Help...
I have a 2010 SS L99. I have put a cold air intake, header, straight pipes and have had it tuned and it dyno at 398 wrhp. Without having to go procharger what else can I do to gain Max horse power? Should I get a performance camshaft kit and replace the manifold or is there a better route to take? I'm open to all suggestions. I'm just trying to get the best HP for the dollar.
gkelsch is offline   Reply With Quote
Old 02-28-2013, 06:59 AM   #2
JEFF75645
Drives: his wife crazy buying mods
I went with cam, heads, and a few other things. Look at my sig, it will give you a general idea.
Also look at the Night Fury cam. It makes alot of power.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 02-28-2013, 07:20 AM   #3
gkelsch
Okay will do, thank you!
Old 02-28-2013, 07:23 AM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If you stay vvt I'd go with the Mast SS cam or the NightFury cam, with some Brian Tooley Platinum springs and SLR Lifters. get a good set of CNCD Ls3 heads from WCCH, AI, LPE, TEA and all the other supporting mods Jeff has in his sig.
Old 02-28-2013, 08:06 AM   #5
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Perform your research & due diligence, some maximum HP cams designed for the strip will actually make your daily driver slower on the street.....yes, its true!
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 02-28-2013, 08:23 AM   #6
gkelsch
That's for the help and feedback. I will do my research now and check out those options suggested. It would be nice to find a manufacture who has a kit with heads and camshaft all from one place so I don't have to mix and match.
Old 02-28-2013, 08:24 AM   #7
gkelsch
Thanks, I meant...
Old 02-28-2013, 08:34 AM   #8
JEFF75645
I think Lingenfelter, Texas Speed and Performance, Lethal, and a couple others have packages.
Old 02-28-2013, 11:48 AM   #9
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Are you looking for more hp specifically or just more performance? Because a new converter or gears would perk things up also.
9/26/09 Took delivery!
Old 02-28-2013, 08:36 PM   #10
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Take your time researching. You should have an end result in mind. You need to to know if your staying NA or FI. That decision effects what mods you want to get and what specs to go with on heads and cam
Mchlgrrsn is offline   Reply With Quote
Old 02-28-2013, 09:20 PM   #11
flyer08
Drives: 2010 2SS/RS
I did tsp vvt-2 cam and put down 428hp/417tq on a mustang Dyno. Will put it ondynojet to compare numbers in April
flyer08 is offline   Reply With Quote
Old 02-28-2013, 09:22 PM   #12
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Dyno jet will show 10 to 15 per cent more
Old 02-28-2013, 09:39 PM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
No need for that bud, it's not going to make a difference only a number on a sig lol. The track will show you the truth.
Old 02-28-2013, 11:12 PM   #14
gkelsch
My end goal is to increase HP and performance the best way possible. I want tobstay away from superchargers and turbos. I would like to gain all the knowledge I can on horsepower gain without chargers and turbos. I have gotten alot of helpful advice on here and I'm going to get the night fury camero package and the tsxr Fast 120mm manifold w throttle body... I don't know anything about the gears and changing them so I will start doing research on them and see if its something I will be able to do in the future. Thanks again for all the help!
