Gen5DIY
Old 02-28-2013, 09:37 AM   #1
villan2
villan2's Avatar
Drives: Camaro ss 2010
March 28 prc cylinder heads results
I purchased PRC 260cc cylinder heads ill have results hopefully March 28...... Current mods cam 226/238 .570/.585 113.5 102 throttle body, 102 manifold, balancer, Cora exhaust, twin disc clutch, tune and dynatech heads 474.87 rp 457.79 rq I hope to make around 510 with heads......
http://m.youtube.com/watch?v=mueG3BPsPxA&feature=plcp
villan2 is offline   Reply With Quote
Old 02-28-2013, 09:46 AM   #2
Gunslinger09
Drives: 2010 Camaro SS
Good luck with it. PRC makes a good head, are you getting a smaller combustion chamber to bump the CR or are you staying with 70CC?
2010 Camaro SS
Black/IOM
Gunslinger09 is offline   Reply With Quote
Old 02-28-2013, 09:48 AM   #3
villan2
villan2's Avatar
68cc
Old 02-28-2013, 10:59 AM   #4
Camper
Banned
Drives: 10' 2SS LS3 M6
I have my doubts you'll hit 500+ with that cam, especially if you arent upping the CR.
Camper is offline   Reply With Quote
Old 02-28-2013, 11:05 AM   #5
blake-b
blake-b's Avatar
Drives: Black 2010
I have the same heads but went with 65cc chambers to bring my CR up to 9.9something. I also went with the hollow intake valves. You will have your dyno results before me. I probably won't get mine until May. They certainly are beautiful in person.
Old 02-28-2013, 11:54 AM   #6
villan2
villan2's Avatar
Doh what cc should I do then?
Old 02-28-2013, 12:03 PM   #7
Gunslinger09
Stock is 70CC.
2010 Camaro SS
Black/IOM
Old 02-28-2013, 12:06 PM   #8
villan2
villan2's Avatar
Is 68cc good or should have I went lower cc?
Old 02-28-2013, 12:09 PM   #9
villan2
villan2's Avatar
I am going to do a procharger and stoker kit also this winter... What chamber size should I have gone with then?
Old 02-28-2013, 12:10 PM   #10
Camper
Banned
it really depends on your longterm goals. If you plan to stay NA and have access to higher octane fuel id suggest calling TSP and giving them your cam size and they can help you with milling requirements (CC's)
Old 02-28-2013, 12:11 PM   #11
Camper
Banned
Originally Posted by Gunslinger09 View Post
Stock is 70CC.
the aftermarket PRC's arent straight across CR based on CC's.
Old 02-28-2013, 12:12 PM   #12
Camper
Banned
keep 68-70
Old 02-28-2013, 12:14 PM   #13
Camper
Banned
did someone recommend this for your blower setup? seems like someone gave you a bad recommendation based on what little I know. you should have went with a 68-70 CC to keep CR around 8.5-9 and also a stronger valve is ideal . maybe someone can chime in with more knowledge than I.
Old 02-28-2013, 12:22 PM   #14
villan2
villan2's Avatar
I called them they said stay with the 68cc camper thanks wanted make sure when I ordered them I kinda forgot to think about that lol
