SDTW Custom Wheels & Tires
Old 02-28-2013, 01:18 PM   #1
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
headers questions
There are so many different t styles out curious what everyone is running and what they recommend.
My current setup is the stock SS exhaust with an SLP loudmouth (muffler delete)
Would I even get the full benefit since I still have the stock cats and such?
There are a lot of cheaper brands (knock offs) that look pretty decent would performance be expected to be the same? Pacesetter, BBK and the pypes kit is cheap
Pros and come between long and short tubes?
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
5th_GEN_SS is offline   Reply With Quote
Old 02-28-2013, 01:35 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If your looking for inexpensive headers go with the TSP's 1 7/8 or 2" because THEY PAY THE BILLS HERE. Just my .2.
Old 02-28-2013, 01:54 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Choosing headers can be a daunting task but here is a little information that might help.
Which Manufacturer Should I Go With?
The good news here is that this is hard to get wrong. Ask around on the forums and you will hear some of the same brand names over and over again. We prefer the major name brand headers like Stainless Works, ARH, Kooks, and Stainless Power. You will never have to worry about quality with any of them and from a performance stand point all of them are pretty close, no one has a secret that makes one brand produce substantially better results than any of the others. If you are looking at other brands here are a few thinks to consider.
Pay attention to what they are made of. Stainless steel (particularly 304) is what you will want to look for. 304 stainless steel will not rust or discolor from exposure to the atmosphere like the cheaper 400 series stainless steel. Unlike aluminized steel, it will not rust from the inside out due to the corrosive fluids produced during combustion. 304 can discolor slightly from getting extremely hot or if you spill engine oil on them but another attribute is that it isnít permanent.
Pay attention to how they are made. CNC mandrel bending is the best manufacturing method for producing exhaust systems and headers that flow and fit well. When this process is used in conjunction with the 304 stainless steel it allows for the use of a thinner wall tubing that will weigh less than other headers. Those weight savings will be offset, however, if you opt for the thermal coating. With stainless steel the coating isnít needed for corrosion resistance purposes (ceramic coating is often pushed because the manufacture is using inferior metal so keep an eye out for that) but it can help reduce under hood temps and looks good.
What Primary Diameter Should I Go With?
This is the area that seems to cause the most confusion but it is fairly straight forward. Header manufacturers usually offer two or three options when is comes to primary diameters for a specific vehicle. For example, for the new 5th generation Camaro SS most manufacturers are offering 1 3/4 inch, 1 7/8 inch, and 2 inch primaries. Here are the some typical numbers on an otherwise stock SS:
Stock: 370 RWHP 375 RWTQ
1 3/4 headers with high flow cats: 400 RWHP 405 RWTQ
1 7/8 headers with high flow cats: 410 RWHP 410 RWTQ
2 headers with high flow cats: 415 RWHP 410 RWTQ
As you can see, simply switching from the restrictive stock manifolds to 1 3/4 long tube headers is worth approximately 30 RWHP and 30 RWTQ on a bone stock Camaro SS. The larger the primary diameter gets the more air the headers will flow and the further up the RPM range the power band is moved. The impact of the larger primary diameters is greater the more powerful the engine is, especially when you introduce forced induction. This means that generally the more power you make or the more race oriented your application is the bigger primary diameter you need, the closer to stock or the more street oriented the smaller primary diameter you need.
In the specific example of the 2010+ Camaro SS, we have found that the 1 7/8 long tube headers are the best all around header for the typical bolt on modified car that is driven regularly and occasionally taken to the track. They offer a tremendous improvement over stock with room to grow as owners modify their car further. The 2 inch headers offer very similar numbers to the 1 7/8 headers up to 5000 RPM where the 2 inch headers pull ahead. They are ideal for those running forced induction or for race applications.
If you have any other questions feel free to shoot me a PM or give us a call. That is what we are here for.
Old 02-28-2013, 02:08 PM   #4
Kelly@PCMofNC
Drives: 2010 RS/SS
Will the same size brand name longtube A vs knockoff longtube B perform the same? Probably. Will brand name long tube hold up MUCH longer and not look totally awful in five years? YES.
Pony up the cash to do it right the first time. Kooks on mine - love them - great performance still look great today!
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 02-28-2013, 02:26 PM   #5
thirdleft152
thirdleft152's Avatar
Drives: 2013 2SS/RS LS3 - Summit White
Thats a lot of input... $0.20.
All joking aside, the real difference between short and long tubes is performance. Short tubes are going to sound better than stock manifold but not give you the performance of long tubes. Diameter sizing is something else to consider, sometimes diameter sizing can restrict performance in stock applications, but not necessarily for newer camaros. I'm not as familiar with them. For instance i've seen some cars with 2" headers put out less power than with their previous 1-3/4" or 1-7/8", almost everyone one of these scenarios is in a mostly stock car. The extra flow can create disturbances not beneficial to an application where its not needed. As you can see from Apex Chase 2" headers almost give you no performance gain in a stock application. Start adding on some serious mods and they will being to be more and more beneficial. And yes for the most part performance is not going to be as big of an issue from brand to brand its really the quality and how long they will last. Apex Chase explains it well.
I recently just got Stainless Works 1-7/8" headers, Magnaflow 3" Comp Series exhaust, and an CAI put on my car and i jumped from 381/377 to 411/406. I love my SW heads.
ADM Race CAI - SW LT - Mangaflow 3" Comp - EE CC
ADM Tuned - 412 rwhp 406 rwtq
thirdleft152 is offline   Reply With Quote
Old 03-01-2013, 03:39 AM   #6
SPCBA
Drives: pleather and Chiclets
american made...kooks, arh, stainless
SPCBA is offline   Reply With Quote
Old 03-01-2013, 04:00 AM   #7
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Umm the dyno comparison I saw of the 3 sizes showed no difference in power in the lower part of the rev range but showed increased power in the upper part of the rev range. Someone correct me if I am wrong but it looked like even on a stock car the 2inch showed no loss in power at ANY RPM vs a 1 3/4inch but a increase in power at higher RPM's. Bottom line is I think everyone should jump right into a 1 7/8 or 2inch header regardless of mods because from the dyno comparison that I have seen there are no tradeoffs going to the bigger primaries.
Old 03-01-2013, 11:44 AM   #8
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
i have dynatech 1 7/8 with offroad pipes and corsa catback.
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-01-2013, 12:37 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
We use KOOKS headers on 90% of our shop installs as their fit and finish is second to none. They are built to last with Tig Welded 304 Stainless steel, 1-Piece Mandrel-Bent Primary Tubes, Merge Collector Spike for better scavenging, Welded o2 Bungs with o2 Extenders included and Ball Flange Collector for great leak free performance. Not to mention they are made in the USA! :flag2:
Feel free to call, PM or email me anytime with questions or pricing. Have a great weekend!
Best regards,
Tyler
888-308-6007
Old 03-01-2013, 07:15 PM   #10
thirdleft152
That is true for those numbers. I am not as familiar with the new camaros, or more specifically the LS3/L99/LSA, however in older cars i have seen people complain about this. A friend of mine had an LS6 CTS-V and he has told me of people getting lesser performance from the larger headers. I also believe this happened on a lot of LT1's. Its very minor discrepancies however i was trying to make the point that for most its not a big difference going with 2".
Old 03-02-2013, 12:03 AM   #11
Supermaro585HP
Drives: 2011 Camaro SS RS
Check out SLP headers. I have had mine 2 years now and no problems at all.. I think I paid $1300.00 for mine. Love the way they woke up my Camaro..
Supermaro585HP is offline   Reply With Quote
Old 03-02-2013, 01:26 AM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
$1300 for SLP's? NO THANK YOU. If I was willing to drop that much coin on a set of headers, they would definitely be Kooks/ARH/Dynatech.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-02-2013, 02:17 AM   #13
SPCBA
I paid less than 1300 for Kooks with flat black ceramic coat inside and out with the green cats....just saying
Old 03-02-2013, 03:18 AM   #14
Garret
Garret's Avatar
Drives: 2013 2SS/RS Victory Red
"green cats" ?
Garret is offline   Reply With Quote
