Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > UK
Old 02-28-2013, 04:23 PM   #1
RickGM
RickGM's Avatar
Drives: 2013 SS V8 L99 Magnusson Heartbeat
What RON Fuel Do You Use
My handbook recommends the use of 98 RON fuel which I take to mean Super Unleaded and that's what I've put in for the 4,000 miles I've knocked up since October. Does everyone else use Super?
UK Camaro Owner. One of a few.
RickGM is offline   Reply With Quote
Old 02-28-2013, 04:58 PM   #2
DWEW
Drives: 2014 Mercedes C63 AMG Coupe 507 Ed
I've been doing likewise and also used the Momentum Premium Unleaded at Tesco
DWEW is offline   Reply With Quote
Old 03-01-2013, 02:14 AM   #3
redleader
redleader
Drives: 2010
95 ordinary unleaded for me.
Anything cheap :-O
*As long as your car is tuned for it* ... put in what you decide... yes Forum people?
redleader is offline   Reply With Quote
Old 03-01-2013, 09:55 AM   #4
stray bullitt
Drives: Bentley Continental GT.
I know the SS (V8) in the 'states has to use premium fuel. However I don't know wether that has been adjusted for the EU spec version. Mine is is a US spec girly V6, so I only need to put el cheapo petrol in .
stray bullitt is offline   Reply With Quote
Old 03-02-2013, 02:41 AM   #5
RickGM
RickGM's Avatar
The handbook suggests that 98 should be used. 95 can be used but can result in poorer acceleration and possibly knocking (pinking to you and me).
Old 07-23-2014, 09:21 AM   #6
Kabz r35 gtr
Drives: 2014 camaro 2ss v8
I'm using 95 on my new car thought it would be fine with that. What do you guys think?
Kabz r35 gtr is offline   Reply With Quote
Old 07-23-2014, 10:37 AM   #7
rikkuness
Drives: 2010 Camaro V6
I've always used Shell vPower Nitro+ which I believe is 99 on my V6, reset the ECU to hopefully get the most out of it, at least if anything it's got some more lubricant in it, can't see it doing any harm.
rikkuness is offline   Reply With Quote
Old 07-23-2014, 10:57 AM   #8
Kabz r35 gtr
Cool thanks for the reply, but can the v8 run on the 95 or is it safer to run 99
Old 07-23-2014, 11:07 AM   #9
RickGM
RickGM's Avatar
There is a significant difference in performance (in my opinion) by using "super" or 98.
If you run the vehicle on just 1 tank of 95 the ECU will adapt and performance will drop. You then need to do a fuse pull to restore maximum performance. After you've done this you will notice a difference. BTW - this only applies to the V8 L99 or LS3 engines and doesn't do anything for the V6's.
Here we go;
http://www.camaro5.com/forums/showth...ight=fuse+pull
Old 07-23-2014, 11:43 AM   #10
rikkuness
I've got an OBD2 reader for my ECU, I wonder if there's anything that I could actually measure to compare the use of lower octane on a V6
Old 07-23-2014, 11:55 AM   #11
Kabz r35 gtr
I've got the L99 so if there's a performance diffrence I'll be doing it.
Old 07-23-2014, 12:02 PM   #12
Kabz r35 gtr
To rick, how long did you leave the fuse out for and how many tanks on 99 did you use before the fuse pull?
Old 07-24-2014, 02:42 AM   #13
RickGM
RickGM's Avatar
Fuse was out overnight. I would suggest letting your tank get as low as you dare and then fill up with super before the fuse pull. If you can wait long enough then maybe after a second tank of super (wouldn't be necessary to get the tank so empty that way - wouldn't want to be stranded out of fuel !) Try after the first option, you can always fuse pull. a second time if you felt it necessary.
Old 07-26-2014, 09:38 PM   #14
Kabz r35 gtr
Thanks rick.
I'll be trying it soon.
