Jason 98 TA
Old 02-28-2013, 04:50 PM   #1
simt3k
Drives: 2011 Camaro RS 2LT
Metrakit steering wheel controls don't work.
I have the metra kit installed and everything works except the volume control and source control on the steering wheel. My stereo is AVH-Pioneer 3300BT.
Its all installed, Is there a separate cable for the steering wheel control or does it need updating or programming?
Any advice would be greatly appreciated.
simt3k is offline   Reply With Quote
Old 02-28-2013, 05:18 PM   #2
simt3k
Am I missing something?
Old 02-28-2013, 11:50 PM   #3
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: SW 11' 2SS/RS LS3 Vert, Blk/Blk
I did the Scosche... but...
Did you do the install yourself?
Did you use a Pac SWI interface? Its about $40; blue unit with several wires... connects from the radio to.stereo with hot wires to the BCU and a neg.... I didn't think it was really necessary; but perhaps for different stereos...
Drago77 is offline   Reply With Quote
Old 03-01-2013, 12:52 AM   #4
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
Did you reprogram the interface the radio??
Wuiquen is offline   Reply With Quote
Old 03-01-2013, 12:55 AM   #5
Wuiquen
Wuiquen's Avatar
In the instructions, it says it might auto detect ur radio but when i install my pioneer it didnt
So i had to reprogram it. Its simple.. read the instructions.. all u have to do if i remember right is hold the volume down button. The led in the interface should start blinking rapidly then u.need to select ur radio number using the volume button. Pioneer is 6. Then i believe u press volume down again and the led should blink 6 times confirming it is recognized... follow the instructions... let me know if u need more help.. ill look at the instructions tom if u need more help
Old 03-11-2013, 12:16 PM   #6
simt3k
Thanks Man I thought I needed to order another part for the kit.
Old 03-11-2013, 12:47 PM   #7
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
My god!!! This is great. I just installed my kenwood and have the same problum. Can't wait to go home and try.
chevy 3 is offline   Reply With Quote
Old 03-11-2013, 01:03 PM   #8
simt3k
http://www.amazon.com/Axxess-ASWC-1-.../dp/B00B4PJC9K
(Axxess Metra ASWC-1 Universal Steering Wheel Control Interface)
Are you guys positive I don't need this cable?
Old 03-12-2013, 02:55 AM   #9
Wuiquen
Wuiquen's Avatar
Positive... all you have to do is once all install if the interface do not recognize the radio (
Controls wont work at the steering), turn the key to acc on, then hold down the volume down until the LED in the inrerface goes solid red. Then release and press Volume up six times which is pioneer number. Then press volume down again.. the LED should blink six times again... and then it should work..
Old 03-12-2013, 08:08 PM   #10
simt3k
hold volume control on steering wheel right?
Old 03-13-2013, 01:08 AM   #11
Wuiquen
Wuiquen's Avatar
Yes.. then volume up on steering too
Old 04-09-2013, 10:14 PM   #12
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
hey guys! i have this problem, i did this steps and nothing happen... can somebody tell me or show me witch is the connection for the wheel control to make sure i got everything right...
Monchy36 is offline   Reply With Quote
Old 04-10-2013, 10:58 AM   #13
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
For a Kenwood it is two times on the up volume. You need to do this within 30 seconds of turning the ignition on. All this info is in the Metra book that came with the interface kit.
Currently in the fleet... 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 04-11-2013, 12:43 PM   #14
Monchy36
Monchy36's Avatar
UPDATE!: searching on why the wheel control was not working finally I find the answer... There's 2 metra kit for the Camaro, 99-3010S and 99-3010S LC... The last one is a basic version that doesn't have the same interface like the original to make it cheaper... So if the OP have the LC he need the hardness for make the wheel control work...
