BeckyD @ James Martin Chevy
Old 02-28-2013, 10:09 PM   #1
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Installing injectors, need help
Got myself a whipple, installing my Id 850s an having some issues. The bores in the blower plenum I swear are too tight. I lubed the bores in the plenum, all bores are smooth, lubed the orings, and CAN NOT push them in. I actually bruised my hand from pushing on the end so hard. I've done injectors numerous times and never had such a hard time. I've split 7 orings so far pushing them in. Some thing is wrong. I will be contacting whipple in the morning but just figured I'd ask here if anyone else has had the issue I'm having. I'm thinking the orings have to be too thick for the plenum. They go in the stock mani no problem. Thanks in advanced!
Caswell239 is offline   Reply With Quote
Old 02-28-2013, 10:19 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Post up some pics bud, you might have the fatter orings in there.
Old 02-28-2013, 10:55 PM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
My next idea is wrap them in paper towel, bag them and stick em on the freezer a few hours while keeping mani on the floor vent. Should be this complicated
Old 02-28-2013, 11:27 PM   #4
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
They are 15mm od orings. I think I remember seeing 14mm orings on ID's web store... Maybe those are the ticket!
Old 03-02-2013, 07:32 PM   #5
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Talked to Ted in another thread and he said you have to use smaller orings. He suggested the blue top oring off the old injectors. Well I put them on and work like a charm!
Ready for fuel rails and to reinstalled
