Old 03-01-2013, 01:38 AM   #1
SPCBA
Drives: pleather and Chiclets
oil cap breather and rear main seal issues
so the consensus is that a oil breather cap with the holes plugged was insufficient and i blew my rear main seal after 2 hard days on a road course. is anyone running 2 catch cans? one for dirty side one for clean.
thinking about buying another catch can or getting the 1le seperator from gm
SPCBA is offline   Reply With Quote
Old 03-01-2013, 08:01 AM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
WTF!!!
Sorry to hear that bud, what are your mods again?
Old 03-01-2013, 09:06 AM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Sorry just saw your other thread.
On my 4th gen's stroker I use the rx oil cap breather and I run a catch can from the Ls2/3 valley cover nipple and instead of plugging it to the intake I run a small breather I got from autozone and I plugged the nipple on the intake manifold and ive never had a problem and i beat my stuff!! Ill post up a pic in a few if you want.
Old 03-01-2013, 10:42 AM   #4
SC2150
Add the 1LE cleanside oil trap and see.
Old 03-01-2013, 12:15 PM   #5
SPCBA
could you post the picks, i am curious. it happened after two days at fontanas road course...i pushed it as hard as my car could go with simple bolt ons with everything else stock. i have since upgraded cam and heads and tune. seal is replaced and good to go so no worries about that...i only wish it was something that failed that i could upgrade hahaha
at fontanas roval i also discovered that i need a better oil cooler...looking at getting one from a zo6 or zr1 retro fitted on my camaro i think.
Old 03-01-2013, 12:16 PM   #6
SPCBA
guess it depends on the price, if its comparable i will use another catch can from a trusted third party i already have the dirty side tackled and it works great!
Old 03-01-2013, 12:22 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Hope this help bud.
This is how it looks...
Here you can see the rx valve cover/oil cap breather.
The hose from the valley cover to the CC.
The nipple that's plugged on the intake manifold behind the throttle cable (black)
The passenger valve cover is plugged.
In essence I eliminated the PCV.
Old 03-01-2013, 12:25 PM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Also some have complained about oil in the engine bay but mine has been dry! Never had an oil residue issue EVER, and I'm a near freak when it comes to engine compartments lol.
Old 03-01-2013, 12:38 PM   #9
SPCBA
great pics...explains it perfectly...you 4th gen guys have already figured out a lot of the tricks for us. appreciate the photos.
Old 03-01-2013, 12:48 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lol just trying to share the wealth bud. I know the routing is a Lil different but you get the idea.
Congrats on your cam results! I'm learning from you 5th gen vvt guys lol
Old 03-01-2013, 01:15 PM   #11
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Not sure if it's applicable, or would help with this particular issue, but saw tips/photos a while back about enlarging the hole in the driver's side valve cover....
90503 is offline   Reply With Quote
Old 03-01-2013, 01:51 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
No need really, with the valley and passenger side vc with breathers crankcase pressures should be ok.
Old 03-01-2013, 02:01 PM   #13
90503
90503's Avatar
Only other time I heard of a rear main seal going out was from the catch-can hoses being connected incorrectly (backwards)...just sayin'...
Old 03-01-2013, 02:24 PM   #14
SC2150
Venting the can defeats all crankcase evacuation. The only reason you build up pressure is the fixed orfice is to restrictive and if using the breather there is no place for the pressure to go if you build excess as it has a oneway checkvalve in it to be emmissions compliant.
Here is the thread explaining the mod.
http://www.camaro5.com/forums/showthread.php?t=239961
If you just vent, then you leave all damaging combustion byproducts in the crankcase. They need to be evacuated while still in a suspended state or each cool cycle after shutdown they condense into the oil and that results in shortened engine life.
