Flowmaster Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 03-01-2013, 02:43 PM   #1
gen3 man
Drives: 1983 z28 perfect body and interior
please help
on a 1983 z28 Camaro 305 cross fire with cruise which speedometer cable goes into the trans the upper or lower
Posted from Camaro5.com App for Android
gen3 man is offline   Reply With Quote
Old 03-02-2013, 07:51 AM   #2
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
There's only 1 speedometer cable on your car. It connects to the driver-side of the tail-shaft section of the transmission and then goes up along the drivers frame rail, into the engine compartment, through the firewall and directly into the Speedometer.
2012 Camaro 2SS/RS - LS3/TR6060: BTR Stage 4, 2" Long Tubes, 3" Exhaust, UDP, NEP OTR, Monster Twin-Disk, 3.91 Gears, Poly Diff Bushings, BMR Toe Arms, Poly Subframe Inserts, ZL1 Mounts, Arun Tuned - 475rwhp 443rwtq
3rdgen3 is offline   Reply With Quote
Old 03-02-2013, 11:28 AM   #3
gen3 man
there is two a lower and an upper one runs from front of car to transmission the other runs from front to cluster it has cruise it's cool though thank you for replying
