SDTW Custom Wheels & Tires
Old 03-02-2013, 03:09 PM   #15
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
Originally Posted by PalmerGA View Post
I have an RX CC so I'm not familiar with yours but, I think we're talking really low pressure here. There are several other hoses/tubes conected to your engine - have you checked to see that you didn't crack some other fitting or loosen a hose while installing the CC?
Yep checked and checked again. It audible sound coming from new rubber hose.
Maybe someone with an elite on lfx can chime in and tell me after warm up do they hear this sound TOO.
Chevyman2 is offline   Reply With Quote
Old 03-02-2013, 03:12 PM   #16
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
Originally Posted by Calikenn View Post
Hey Chevyman...can you plz post some pics of the mounting of the can in your engine bay? Thanks in advance!
Yep2
Old 03-02-2013, 03:30 PM   #17
Calikenn
Calikenn's Avatar
Drives: 2012 Corvette GS
That looks great Chevy man....thanks again. For posting! Enjoy.
Calikenn is offline   Reply With Quote
Old 03-02-2013, 05:36 PM   #18
SC2150
Sound is normal as long as you verified no vacuum leaks. Can should never be under pressure, only vacuum.
Old 03-02-2013, 08:07 PM   #19
jameslk55
jameslk55's Avatar
Drives: 2012 2LT/RS, 2005 SLK55 AMG
The top and side fittings, did you tighten them as much as you could?
jameslk55 is offline   Reply With Quote
Old 03-02-2013, 11:11 PM   #20
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
Yep as much as possible did not want to wring it off. It's not leaking just loud as hell.
Old 03-03-2013, 07:23 AM   #21
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Odd, I know I have a V8 but I have no hissing sound at all.
Scott@Bjorn3D is online now   Reply With Quote
Old 03-03-2013, 09:00 AM   #22
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
I have no hissing and no oil because my vave seals and pistons rings are seated well and should be for a long time................many people on here have shown so much oil I would be worried about their cars at such low miles that they have they have not had things sealed as tight as they should be....I know i used to build my own engines, and build my own hot rods..........The v-8 pcv is right by the throttle body and the return line also, you nave so much noise probably because the line on your v-6 goes right up to the middle of the cylinder banks to the intake plenum and somehow to a side of the cylinder heads?
Old 03-03-2013, 03:47 PM   #23
jameslk55
jameslk55's Avatar
What do you mean wring it off? It would only fall off if it's loosened by turning it to the left all the way. I turned it to the right until it was tight and where I wanted it to be pointing. If either fitting is easily adjusted by hand, I would tighten them with a tool. That's just my guess. Other than that, try connecting the hose back to the stock PCV location and bypass the catch can. See if there's any difference in sound.
Old 03-03-2013, 08:19 PM   #24
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
[QUOTE=jameslk350;6240135]What do you mean wring it off?
WRING OFF AKA TO TORQUE (tighten) to point which breaks or strips threads.
Yes I tightened with wrench.
Thanks ...I'm almost certain at this point the sound is from the turbulence of flow moving through the soft rubber hose. The oem was rigid design and its I.D. was smaller.
Few different folks sent me pm's describing this very sound in thier hoses after they installed catch can themselves so apparently this is normal.
Keep in mind it is not heard on startup only after couple minutes running then its audible vacuum leak sound.
Old 03-03-2013, 08:31 PM   #25
jameslk55
jameslk55's Avatar
I actually switched the hoses out for transmission hoses for my installation. They're a bit more rigid.
Old 03-03-2013, 08:40 PM   #26
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
Ok I keep that in mind.
Old 04-09-2013, 12:36 PM   #27
Rob21sf
Rob21sf's Avatar
Drives: Black 2011 Camaro LLT
same here
Did you figure out the cause of the hissing sound? My LS is experiencing the same thing right now. No visible leaks, catch can collecting oil as it should be doing, just don't know why the noise?
To all the Pro's out there, can my recent addition of Ice-olator, ported TB, and plenum spacer be contributing factor in the hissing noise. Meaning with all the extra air the car is now pulling in cause this?
Rob21sf is offline   Reply With Quote
Old 04-09-2013, 12:38 PM   #28
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You still planning to come by tonight?
Sent from my 2SS/RS
FSP tuned: 377/389
