JUICEDMOTORSPORTS
Old 04-19-2013, 08:29 AM   #29
Rob21sf
Rob21sf's Avatar
Drives: Black 2011 Camaro LLT
I think I figured it out!
Well, since my Elite CC was also making this noise on my LLT, I decided to take the fittings off and put new telflon tape on it just to be sure no leak. As I removed the top fitting, I looked inside and noticed in the filter chamber they use some sort of "Scotchbrite" looking material on top of the filter element, that's when I realized that was the cause of the "hissing" noise!
If you take a piece of paper and blow on the edge you hear that sound, now multiply that a couple of times and you get the "hissing" noise. I trully believe the rush of air into that chamber creates that effect. Also, the sound might be more pronounced if you have Ice-olator, plenum spacer, or Ported TB installed.
Rob21sf is offline   Reply With Quote
Old 04-19-2013, 10:28 AM   #30
SC2150
This is probably not an issue.....a hiss in most cans is as described above is normal, but yes, stiff wall hoses are reccomended so there is chance of collapsing under vacuum. There should be no pressure in any can. Also, if you have a vacuum leak this will usually trip a CEL for a lean conditon, so if that is not happening I would not be very concerned.
One last thing to keep in mind is the serpentine belt hisses (the more miles, the louder) and the brake/vacuum booster pump is right where most cans are mounted so that makes a hiss as well.
Old 05-11-2013, 08:57 PM   #31
sternfan69
Drives: Black 2011 2SS/RS M6
I hear this sound as well just after installing ported throttle body and catch an.
sternfan69 is offline   Reply With Quote
Old 05-11-2013, 10:02 PM   #32
Rob21sf
Rob21sf's Avatar
Nothing to worry about as long as you did the install correctly.
Old 05-12-2013, 10:39 AM   #33
SC2150
Always use a stiff wall hose like trans cooler hose or hydraulic rated. Fuel line becomes to sift and collapses under vacuum. And all cans will have noise from the flow through them.
Old 05-13-2013, 12:41 PM   #34
wtb
Drives: 2013 1LT Blue Ray Met
Elite catch can mod
This is how I installed my Elite can. I first added a drain port in the bottom to make it easier to check for any drip, and the used ss fitting and tubing to route beneath engine cover.
wtb is offline   Reply With Quote
Old 05-13-2013, 02:17 PM   #35
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
I was just about to order one of these when I found this thread.. It appears this is nothing to be worried about, but is the sound so loud you year it inside? If windows down is there a pronounced "hissing" sound as described??
TwentyTen2SSRS is offline   Reply With Quote
Old 05-15-2013, 12:45 PM   #36
2fullgarage
Mid-Florida Camaro Club
2fullgarage's Avatar
Drives: 2013 LFX A6
All I can say is remember to check the PCV connection on top of the intake. I moved my car during installation (when I dropped the lock washer) and the car sounded like crap with it not locked in place
2 FULL GARAGE
2003 silver streak mica MR2 Spyder, 6-SMT, AEM, TM Magnaflow duals, Davids style bars, CHE header, body kit that required a lot of hand work
NOW GARAGED
1993 flash red t-top MR2..way too many mods
NOW GARAGED
2013..Elite catch can, ZL1 NPP Exhaust, CAI, GM front, Razzi sides, Stillen rear, T-REX grill, stripes, paint, LED inside and under
2fullgarage is offline   Reply With Quote
Old 05-15-2013, 12:50 PM   #37
TwentyTen2SSRS
Drives: 2010 2SS/RS
Is the tubing included with the catch can??
Old 05-15-2013, 12:53 PM   #38
13FastBlkSS
Drives: 2013 Camaro 2SS/RS M6
Yes, everything needed to install it will be included.
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs
Build#24869
13FastBlkSS is offline   Reply With Quote
Old 05-15-2013, 12:55 PM   #39
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Yes they are. Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 05-15-2013, 02:16 PM   #40
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Are all Elite cans supposed to have this little drain whole on the bottom? My Black Elite can does not have it and i recently just got it a couple months ago.
Here is a picture showing what I'm talking about.
Proud owner of litho #179 Click Picture for Build Thread
Old 05-15-2013, 02:24 PM   #41
13FastBlkSS
No, the OP said he made the hole to make it easier to drain..
Build#24869
Old 05-15-2013, 02:25 PM   #42
JDP Sales
JDP Sales's Avatar
No, that was added on by the person that bought it. Not really sure why though. I prefer to unscrew the can and dump it.
Best regards,
Tyler
888-308-6007
