Old 03-02-2013, 10:07 PM   #1
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 944 RWHP/787 RWTQ
Kooks Lt Headers and "Green" High Flow Cats
Anyone running the full Kooks setup with LT headers and green cats? Kooks claims their setup will pass emissions testing and I was just curious if anyone can vouch for that.
Thanks!
BiggFooT
F-1X, Cog Drive, ATI Super Pulley/Sprag
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Twin Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
?? second 1/4 mile
BiggFoot is offline   Reply With Quote
Old 03-02-2013, 10:35 PM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I'm running them but don't have to test emissions anytime soon.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 03-02-2013, 11:12 PM   #3
SPCBA
Drives: pleather and Chiclets
http://www.camaro5.com/forums/showthread.php?t=274396
just be warned without tune you will run lean at wide open throttle.
SPCBA is offline   Reply With Quote
Old 03-05-2013, 04:59 PM   #4
BiggFoot
BiggFoot's Avatar
Thanks for the reply John . . . How do you like the sound?
Blower Cam
?? second 1/4 mile
Old 03-05-2013, 05:02 PM   #5
BiggFoot
BiggFoot's Avatar
I already have a tune with a Stainless Works setup (LT headers, cats, X-pipe, and mufflers) but I will talk to the G-Force guys to see if we need to take another look.
Thanks!
Blower Cam
?? second 1/4 mile
Old 03-05-2013, 07:06 PM   #6
Pro Stock John
Writer
I like how mine sound but frankly you're way more modded, how does yours sound.
PROJECT HEAVY CHEVY
Old 03-05-2013, 07:19 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
If you already have headers and HFC's why do you want to change them?
Best regards,
Tyler
888-308-6007
Old 03-05-2013, 07:26 PM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Thanks!
Green cats with a TVS blower and cam?
Good luck with that!
No bueno!
Old 03-05-2013, 07:34 PM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
[QUOTE=litle88;6249559]Green cats with a TVS blower and cam?
No bueno![/QUOTE
Cats don't like boost ... No matter which ones you get. They will come apart. Cat delete is the way to go
Mchlgrrsn is offline   Reply With Quote
Old 03-05-2013, 07:49 PM   #10
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
Thanks!
BiggFooT
I can't believe Kooks would say they would pass emissions testing....
It depends totally on each States rules and Technically the Feds forbid any emission control tampering at all.
For instance,It would never pass the Visual test in several states because the Cats are moved from their original location regardless if they sniff clean or not.
Other states forbid modifying or moving perfectly working Cats.
Just make sure it works where you live and your good.
I know it sounds crazy but that's how it's always been.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 03-05-2013, 09:24 PM   #11
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
No LT headers are emissions legal because they remove or replace the factory cats. That is why they are all sold for off road use. The big thing about green cats is they are much cleaner than normal high flows, and because they do not throw check engine lights, they do not require a tune.
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
* CURRENT SALES * ORDER TERMS * DISCOUNT POLICY
MarylandSpeed is offline   Reply With Quote
Old 03-05-2013, 10:02 PM   #12
BiggFoot
BiggFoot's Avatar
[QUOTE=Mchlgrrsn;6249594]
No bueno![/QUOTE
Yeah I am currently running gutted cats because I blew out one and it lodged in the X-pipe. I was having the DSS drive shaft, axles, 9" conversion, and gears installed and one of the mechanics just happened to see the plugged X-pipe when they dropped the exhaust for better access during installation.
I am willing to change out the entire exhaust system if it will pass the Texas emissions test.
Blower Cam
?? second 1/4 mile
Old 03-05-2013, 10:06 PM   #13
BiggFoot
BiggFoot's Avatar
Actally the Stainless Works system sounds awesome, however when I had the cats gutted I picked up an annoying backdraft (wughhhhh) sound when I shift gears at about 4000 rpm or so. If I hammer down on it and shift near redline it wont do that though.
Blower Cam
?? second 1/4 mile
Old 03-05-2013, 10:09 PM   #14
BiggFoot
BiggFoot's Avatar
Kooks supposedly teamed up with an emissions testing company to develop the "green" cats. I understand that others in my area have tried the green cats and passed the emissions testing.
Blower Cam
?? second 1/4 mile
