Jason 98 TA
Old 03-04-2013, 11:36 AM   #29
FosterSS
Guardians Of The Night
FosterSS's Avatar
Drives: Chevy
Originally Posted by litle88 View Post
^^ I see you had that feeling hu? Lol^^
Glad to see you caught it on time!!
Nice numbers
Yeah, her and I are pretty close. haha
Thanks though. Need to get my heads ported to push that 500 club!
(SOLD)2011 SS LS3- All Black, Cammed w/ a few other mods...
1968 SS 396- currently being restored.
FosterSS is offline   Reply With Quote
Old 03-04-2013, 08:20 PM   #30
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2010 2SS/RS L99
I swapped out my good L99 pump for a Melling when I installed a cam. The L99 is ok but a bunch of folks had issues with the LS3 pumps even stock. I personally think it's an installation issue even when installed in the factory. This is the main reason they fail.
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
1Camaro2SS is offline   Reply With Quote
Old 03-04-2013, 08:27 PM   #31
1Camaro2SS
1Camaro2SS's Avatar
For some reason the L99 pump can handle more misalignment on the crankshaft therefore they don't fail.
Old 03-04-2013, 08:28 PM   #32
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
How do you install a pump wrong?
MODS:
Old 03-04-2013, 08:33 PM   #33
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Not centered around the crank snout right.
Old 03-04-2013, 08:47 PM   #34
1Camaro2SS
1Camaro2SS's Avatar
Here is the proper way to install the pump using feeler gauges to make sure there is enough clearance.
Old 03-04-2013, 11:33 PM   #35
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
I had an oil pump failure last month and reported it here there is a thread my is an l99 my oil pressure would be low at idle like 10 or 15 psi and was noisy like lifters except coming from the pulley area dealer at first thught it was the lifters replaced under warranty
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 03-04-2013, 11:40 PM   #36
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I install pumps with the bolts just finger tight, spin the engine over by hand two rotations and then torque the bolts down. My LS3 takes 8qts dead on the money BTW.
Old 03-04-2013, 11:46 PM   #37
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
Really?! I picked up my GM HO pump this afternoon for my replacement. I chose not to go with a Melling because I had two of them go out on me years ago; 1 on my 01 TA WS6 and 1 on my 96 Z28 LT1. Both were modded motors built with Mellings. There wont be a 3rd time.
gnturboray is offline   Reply With Quote
Old 03-05-2013, 06:32 AM   #38
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
And I thought that was an L99 thing! I didn't know Ls3's took 8 quarts too lol.
I've done the pumps the same way myself But only Mellings.
Old 03-05-2013, 07:09 PM   #39
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
http://www.camaro5.com/forums/showpo...&postcount=108
I went with the dealer's advise, at least it's warranted
Given a choice, go with high volume, not pressure.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 03-05-2013, 07:20 PM   #40
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Sorry but I'd rather be on my own!
The Mellings are blueprinted and are made of better materials. That's the reason your valve relief was stuck open/closed because of the materials. But yes I agree use the high volume one ie 10296 and it comes with a high pressure spring if you'd like.
Old 03-05-2013, 10:54 PM   #41
1Camaro2SS
1Camaro2SS's Avatar
My stock pump was so tight on one side of the crank, I couldn't stick my thinnest feeler gauge in there. This causes friction which can lead to possible valve relief getting stuck. Either the pump was slapped in from the factory or it shifted over time.
Old 04-14-2013, 08:52 AM   #42
CFD
Drives: 2SS/RS L99 BLACK
Loolks like I may have lost my oil pump on an L99. Just about pulling into my shop I lost oil pressure and the valve train started getting noisy. Checked oil level, all is fine. Going to try to make some room in my shop today and get it in so I can check it out further. I'll keep everyone posted on my findings once I get into it.
CFD is online now   Reply With Quote
