SDTW Custom Wheels & Tires
Old 04-15-2013, 05:02 PM   #71
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yes all Ls's use the same chain, is that what you mean?
Old 04-15-2013, 05:04 PM   #72
LeanPocket
Drives: 2010 2SS
i believe there is a service bulletin on the ls3 oil pumps
they can go out at any time from what ive been told
l99 oil pumps work very well.
LeanPocket is offline   Reply With Quote
Old 04-15-2013, 05:06 PM   #73
CFD
Drives: 2SS/RS L99 BLACK
Yes. I wasn't sure if a beefier chain would have clearence issues with the cam phaser.
CFD is offline   Reply With Quote
Old 04-15-2013, 05:07 PM   #74
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I see some pretty deep pits on the rotors bud and on the inside of the cover I see some long scratches. Or is it just me.
Old 04-15-2013, 05:07 PM   #75
CFD
This is an L99,
Old 04-15-2013, 05:14 PM   #76
CFD
The pictures are decieving. The rotors are pretty clean, I did revove them and the housing is clean as well. There are a couple of scratches on the cover but they are not in any way enough to cause a loss in oil pressure. When I get the pump out I will clean and examine it closely and post better pics as well but the gear/housing part of the pump is not the problem. I'm wondering if I can detect a stuck relief valve without possibly causing it to free and re-seat properly. I am very curious as to if that is the problem although I don't see what else it can be unless I'm missing something.
Old 04-15-2013, 05:33 PM   #77
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
The katech C5r timing chain is considerably beefier and it's the same size. It has a "0" failure rate in their racing program and those are hard miles lol.
Old 04-15-2013, 05:39 PM   #78
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Oh ok gotcha!
Old 04-15-2013, 06:14 PM   #79
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
Originally Posted by rare991 View Post
so you get a better pump for a weaker link... makes no sense. I have an L99 and I cant wait to get the LS3 conversion
+1
But at least it's nice to know you don't have to change the oil pump!
LOL.
But, the skip shift eliminator is a lot cheaper than an LS3 conversion.
GEEKFREEKSCOTTY is offline   Reply With Quote
Old 04-15-2013, 06:57 PM   #80
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Originally Posted by GEEKFREEKSCOTTY View Post
+1
LOL.
Lmao between you and rare991? You guys have confused the shiat outta me lol
The OP has an L99 and they have been better than Ls3 pumps thus far.
The only weak link between L99's and Ls3's are those DOD lifters. I confused lol.
Old 04-15-2013, 07:00 PM   #81
GEEKFREEKSCOTTY
Just referring to things that need to be changed out to make the L99 & LS3 more of a an "equal"..
I didn't know that the L99 oil pump was better until I read that info here.
But it still doesn't make up for the fact I have to do an LS3 conversion to get my "26 hp" back.
Old 04-15-2013, 07:57 PM   #82
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lol
Old 04-16-2013, 04:41 AM   #83
Mr pogo
Drives: 96 Imp SS, 13 Camaro 2SS AGM
is that the relief valve at the 3:30 position??
have not worked on a LS engine yet, all the previous gen small blocks had the relief valve in the oil filter housing.
Mr pogo is offline   Reply With Quote
Old 04-16-2013, 10:58 AM   #84
CGT
Drives: 2011 SSm6
I work at a large Chevrolet dealership, still haven't seen an oil pump failure on a Camaro come through the door yet. Maybe itll take more time and mileage before I start seeing them.
CGT is offline   Reply With Quote
