Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 03-02-2013, 11:08 PM   #1
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: Black 2010 2SS/RS M6
Question on what CAM?
I'm looking to get in a cam and not spend $500. I'm not going to ever do FI. Headers and gears and tune eventually.
Thanks in advance.
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 03-02-2013, 11:40 PM   #2
SPCBA
Drives: pleather and Chiclets
dont know your needs or how you drive your car...
SPCBA is offline   Reply With Quote
Old 03-02-2013, 11:43 PM   #3
BRAVO 2SS
BRAVO 2SS's Avatar
It's a DD...won't ever see a track
2010 Camaro 2SS/RS
Old 03-03-2013, 12:48 AM   #4
SPCBA
no track time? keep stock cam or ls9 cam. american made headers with a quality intake and a tune done by a pro. people have issues with the ls3 oil pump if you want to replace that for piece of mind. also upgraded chain wouldnt hurt.
but seriously if no track time and daily driver should do all the bolt ons first before you go to internals...bolts may be enough for your application, and if not they are crucial supporting mods to anything else. goodluck
Old 03-03-2013, 06:26 AM   #5
Gunslinger09
Drives: 2010 Camaro SS
You should do the headers first. Then do an Ls7 cam and good tune. Make sure you get the correct length pushrods and call it a day. The LS7 cam is the same specs as the LS9 cam with a tighter lobe seperation angle. It will make more TQ and make power at higher revs than the stock cam.
2010 Camaro SS
Black/IOM
Gunslinger09 is offline   Reply With Quote
Old 03-03-2013, 06:31 AM   #6
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
i second that. i would for sure do bolt ons first. you may be content with the new found power and not have to cam
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-03-2013, 08:48 AM   #7
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
Yep I agree! Are you wanting to do the Cam first for any particular reason?
If not, finish the bolt ons first. If you do cam I am pretty sure you will have to pay for a tune at that time. Plus you will want to upgrade oil pump and chain for piece of mind with all the failures. I dont see this happening for under 500.
Headers will give a little bit of power and a better sound!
And if that dont work do this! haha
Thanks in advance.
TSP VVT2, OBX LTs Catless mids, Flowmaster, Half K&N, Half Fastlane Pipeline CAI, Tuned by RDP Motorsports! Thats the main fun adders
SHAKE ANNNNNNND BAKE!!!!!
rahallfly is offline   Reply With Quote
Old 03-03-2013, 08:59 AM   #8
biggerisbetter
lll
would this help my mpg as well
PERFORMANCE
APPEARANCE
Old 03-03-2013, 09:24 AM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Thanks in advance.
air in and air out is always the first step .. finished off with a good tune
CAI and exhust first
Mchlgrrsn is offline   Reply With Quote
Old 03-03-2013, 09:27 AM   #10
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
I am not sure.. you would have to factor in the Gas usage of the leafblower also and 2 stroke oil to mix haha
Old 03-03-2013, 10:10 AM   #11
biggerisbetter
lll
damn i think that will put me over budget haha
PERFORMANCE
APPEARANCE
Old 03-03-2013, 10:19 AM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Thanks in advance.
1) You live in the "People's Republic of California"
2) you don't want headers now
3) you don't want gears now
4) you don't want to to tune it now
5) your budget is 500 for a cam
6) it's your daily driver
7) you obviously don't have money to play bud.
Shit still happens, especially cutting corners and budget building. Either you do once and do it right or be prepared to spend twice.
Old 03-03-2013, 10:39 AM   #13
mikeSS
mikeSS's Avatar
Drives: 2015 c7
Old 03-03-2013, 04:43 PM   #14
BRAVO 2SS
BRAVO 2SS's Avatar
I guess I should've clarify...yes I am doing headers first. Looking at kooks or Stainless Power...not sure if the extra $ is worth it for kooks and definitely a tune with this. Then Cam...I was just trying to figure out what Cam would fit my needs. I already have an Intake.
I know this State is definitely going to hell...I love the weather but Politics suck! Maybe I should move to Texas! :flag2:
I do have money to play...I just don't want to spend a ridiculous amount of money on a Cam and was seeing what others were using. Obviously different Cams for different needs. But your advice is appreciated.
sounds like good advice!
Thank you all for your advice...going to search for more info on headers and a tune!
2010 Camaro 2SS/RS
