Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 03-03-2013, 05:54 PM   #15
mikeSS
mikeSS's Avatar
Drives: 2015 c7
Originally Posted by BRAVO 2SS View Post
I do have money to play...I just don't want to spend a ridiculous amount of money on a Cam and was seeing what others were using. Obviously different Cams for different needs. But your advice is appreciated.
Its really not a ridiculous amount of money for what you get.
Old 03-03-2013, 05:56 PM   #16
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
+1
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-03-2013, 06:05 PM   #17
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
you can get a decent cam under $500...there and many out there. but its the supporting mods that go with it that quickly run the price up. replacing bolts, gears, chains, valve springs, push rods...its not as simple as buying a cam and calling it a day. be prepared to spend around $1200 total including additional parts. just look up any of the "cam kits" and you will quickly see the necessity items that go WITH the cam. if your doing the install yourself, great, as long as you have the tools. but the tune...that'll cost you too. generally starting at a minimum of $400 for just the programmer and additional $$$ for the tune itself.
so with a complete "cam kit" and tuning and extras like fluids expect your "cam budget" to be right around $2000...and you can probably just about double that if you pay to have the work done at a shop. some places will do a complete CAM only package at a fairly reasonable price to include tuning for under $3000.
or a COMPLETE package for $5200:
http://www.jreperformanceparts.com/2...t-package.html
but seeing how you live in CA...good luck with any of that when it comes inspection time.
hapisok is offline   Reply With Quote
Old 03-03-2013, 06:10 PM   #18
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Originally Posted by litle88 View Post
7) you obviously don't have money to play bud.
Without a college degree or at least 2 years experience in anything you're pretty much stuck with low paying dead-end fast food jobs, or a bag boy or cashier at a grocery store.....
11.90's w/headers, CAI, tune, & some high-test (no bling).
Smirnoff is offline   Reply With Quote
Old 03-03-2013, 06:11 PM   #19
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: Black 2010 2SS/RS M6
Yea...I have a hook up for the inspection.
Definitely prepared to spend $2,000-$3,000 on a complete "cam kit"! Just looking at what kind of cam and what price.
Thank you for the advice! I really do appreciate it!
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 03-03-2013, 06:27 PM   #20
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
A lot of the posts have given good advice. To do a cam correctly is going to be around $1300.00. This is after headers and hi flo cats. No use doing a cam before you can get the increased air flow out. I think your wasting your money on an LS7 or 9 cam. Same effort to install and you don't get much of an increase. I had Vengeance install there Stage II cam and the drivability is good. Look around at what some of the cars on here are running and PM the owners and ask questions about how there car drives is the best answer I can give you.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 03-03-2013, 06:28 PM   #21
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
buy a cam 500 bucks or less
buy springs 200-300
push rods 100
tune 300-500
install 300-500
bolts gaskets and antifreeze 50
just guessing on prices. i had this done for around 1200 bucks . but diff areas means diff prices
the other stuff is for piece of mind. i didnt do anything else but what i listed above to my car. i know a few others that did the same and doing fine . just know that if someone else does it for u , do research on them and ask around .
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 03-03-2013, 07:40 PM   #22
hapisok
hapisok's Avatar
What kind of hp are you looking for? Top end...mid range. tq vs hp.
There are quite a few options out there...lethal, vengeance, jre, lg...or you can hit up ed curtis and get a custom grind based on your setup and end goal. Thats what I did...I'll be posting my specs and numbers after install in a few weeks.
Old 03-04-2013, 08:44 AM   #23
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
You can run the cam that I have, its a newer Lunati voodoo ground for the ls3 heads. I am running this cam with the stock valve train... its only .565 lift and ground on a 112. With headers and a tune its making around 450 at the wheels, has a nice lope at idle and the drivability is not much different then stock. Little88 knows my car, its runs hard and the cam has been in my car for a year now with 10k miles, no issues.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-04-2013, 09:18 AM   #24
JEFF75645
Drives: his wife crazy buying mods
As litle said do it right the first time. I installed a small cam and now im about to go back in to install bigger cam and stall.
Man you LS3 guys have it easy on cam installs. My whole set up was over 5000.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 03-04-2013, 11:25 AM   #25
Jason 98 TA
Drives: Camaro
Give us a call & we can go over options with you. It helps to discuss the car & goals with you & from there we can put you together a good combo that will make the best possible power for your goals & $$$.
Jason 98 TA is offline   Reply With Quote
Old 03-04-2013, 11:47 AM   #26
SPCBA
Drives: pleather and Chiclets
I guess I should've clarify...yes I am doing headers first. Looking at kooks or Stainless Power...not sure if the extra $ is worth it for kooks and definitely a tune with this. Then Cam...I was just trying to figure out what Cam would fit my needs. I already have an Intake.
I know this State is definitely going to hell...I love the weather but Politics suck! Maybe I should move to Texas! :flag2:
sounds like good advice!
Thank you all for your advice...going to search for more info on headers and a tune!
you have a poor intake...one that heat soaks and doesnt close off the engine air very well. if you know you are getting a tune have your tuner custom spec a grind for you. can always find a tuner through your local regional forum
SPCBA is offline   Reply With Quote
Old 05-06-2013, 06:03 PM   #27
BRAVO 2SS
BRAVO 2SS's Avatar
Ok...so I got the kooks headers with high flow cats...ported throttle body and power bond 25% UD pulley and Vararam intake...so before I go get a tune...I was thinking...why not get the cam taken care of!
So with me living in the peoples republic of CA....what's a good smog legal cam? I know almost an oxymoron... but I have to be able to pass smog.
2010 Camaro 2SS/RS
Old 05-06-2013, 06:18 PM   #28
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
So you should already be tuned if you have installed those parts and I'm thinking the long tube headers already kills your smog test. I could be wrong.
