SDTW Custom Wheels & Tires
Old 03-03-2013, 12:39 PM   #1
gafool
gafool's Avatar
Drives: 2010 1SS CGM
L99 to LS3 kits?
2010, 2011, 2012, 2013 Camaro SS GM L99 Conversion to GM LS3 - Camshaft & Cylinder Head Installation Kit #L99TOLS3
Read more: http://www.phastekperformance.com/20...Conversion-LS3
now the only thing missing is a cam correct? or is this a stand alone kit?
gafool is offline   Reply With Quote
Old 03-03-2013, 12:53 PM   #2
MrGs SS
MrGs SS's Avatar
Drives: 2013 Black SS/RS
You would still need a cam and associated hardware.
2013 2SS Black~ L99
Performance Mods-CAI intake, APEX washer bottle relocate and scoop, Ported TB. SLP 160 degree stat, Norris Catch-can, Pfadt Tri-Y headers, BMR F/R sway bars and Arms, Corsa cat back exhaust.
Appearance Mods-Blackout kit (markers, tail lights), black tail light bezels, black chrome trunk lettering, LSR billet engine dress-up kit, sub box. Billet tensioner pulley and thermostat housing (Billetcustom), Heritage grille.
Tuned by Matt @ Florida Speed and Power
379/388 Mustang dyno
MrGs SS is offline   Reply With Quote
Old 03-03-2013, 01:07 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
All you'll need is your valvetrain, ie pushrods, lifters, cam and valve springs bud.
I would suggest to you getting a specd cam from Ed Curtis (flowtech) or Brian Tooley (Brian Tooley racing) or the night fury.
I'd also suggest valve springs/pushrods and lifters from Brian Tooley
http://www.briantooleyracing.com/lifters.html
http://www.briantooleyracing.com/spr...s-engines.html
http://www.briantooleyracing.com/pushrods/
Just trying to trying to show you parts that have proven to be quality stuff!
Old 03-03-2013, 02:36 PM   #4
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
Yep what litle said!!
Have you thought about staying VVT? The cams that keep the AFM are kinda weak, but if you do a VVT cam and an AFM delete it you do 95% of what is in that conversion kit. The VVT cams are making good power. I just installed TSP's VVT2 Cam and got their AFM delete kit with it.
Just an option not really sure what your goal is or what your looking for.
[QUOTE=litle88;6239626]All you'll need is your valvetrain, ie pushrods, lifters, cam and valve springs bud.
TSP VVT2, OBX LTs Catless mids, Flowmaster, Half K&N, Half Fastlane Pipeline CAI, Tuned by RDP Motorsports! Thats the main fun adders
SHAKE ANNNNNNND BAKE!!!!!
rahallfly is offline   Reply With Quote
Old 03-03-2013, 02:46 PM   #5
SPCBA
Drives: pleather and Chiclets
vvt good afm/dod bad
SPCBA is offline   Reply With Quote
Old 03-03-2013, 03:01 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If you stay vvt, you'll need someone that "knows" exactly what they are doing with vvt.
Old 03-03-2013, 05:34 PM   #7
gafool
gafool's Avatar
seems simpler to just do a cam so i might look into that thanks for the replys,
Old 03-03-2013, 07:24 PM   #8
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
The DOD/VVT delete from that Phastec link above is crazy expensive. Try the delete kit from LPE. Maryland Speed sells it and its much cheaper.
Other items recommended
-trunion upgrade,
-C5R timing chain,
-pushrods measured for correct length(these you will have to order in the middle of the cam install),
-valve spring kit that is recommended for your paticular cam(if you get new heads at the same time they will already include this),
-cam of choice
-maybe a Meling oil pump(debateable)
-CNC ported or aftermarket heads if you have the extra coin
-new head gaskets (I like LS9 but you can get LS3 replacement if FI is not in your future)
-aftermarket torque converter speced for your car and cam.
Old 03-03-2013, 07:59 PM   #9
gafool
gafool's Avatar
well ill just do the headers and exhaust and tune this tax season plus add the 160 thermo
so the cam will come next yr unless i win the lotto!
Old 03-03-2013, 08:35 PM   #10
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
The way i did this so that a shop who are not VVT experts is i had TSP put the tables and tune on my PCM. So when i take it to a shop who is familiar with non vvt LS engines they can fine tune the tune and already have the tables from the guys who made the kit
Old 03-04-2013, 12:23 AM   #11
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
I just went all in with the night fury all im waiting for now is the stall converter and digging time it is for me lol
Nightmare2012 is offline   Reply With Quote
Old 03-04-2013, 02:06 AM   #12
SPCBA
i think tsp can also send the cam phaser tables to the tuner via hp tuners...that means the tuner would need to have hp tuners as well.
Old 03-04-2013, 02:09 AM   #13
SPCBA
-trunion upgrade,
-C5R timing chain,
-cam of choice
the only thing i would say is i have yet to personally see or know anyone who has had issues with the l99 pump, and unless the cam is to big for the stock converter then yes you would need a bigger stall.
stalls are great for the strip, not so much for autox and road courses.
