Emblempros
Old 03-03-2013, 07:05 PM   #1
Crashnburn7
Crashnburn7's Avatar
Drives: 2010 Camaro 2SS/RS
Stabilitrack Servicing
Not sure if this is the right place to post, but its definatley the most viewed...soooo,
My car has been in the garage all winter, I was setting up my tuner and getting ready to send my stock to ted.
Afterwards I started my car up and in the "info gauge"(dont know what else to call it), It said my stabilitrack needs servicing.
Is this just from it sitting all winter? or did I do something I didnt realize? or does it really need servicing? Why would it need servicing? I dont get it!!!
Advice appreciated,
Steve
Crashnburn7 is offline   Reply With Quote
Old 03-03-2013, 07:12 PM   #2
gutterball
gutterball's Avatar
Drives: 2011 1LS M6 Supercharged
Send a message via AIM to gutterball
Mine did that once, Shutting the car off to get Gas, after restart. never saw it again.
gutterball is offline   Reply With Quote
Old 03-03-2013, 07:16 PM   #3
Crashnburn7
Tried restarting it 3 times since early this afternoon, Has done it everytime
Old 03-03-2013, 07:24 PM   #4
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
try disconnecting the battery for 30 mins and also make sure all your spark plug wires are hooked up
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-03-2013, 07:26 PM   #5
Crashnburn7
what would spark plug wires have to do with it?
havent opened the hood or even taken it out of the garage since november, how would they have come loose?
Old 03-03-2013, 07:29 PM   #6
GnyaTek
GnyaTek's Avatar
Drives: 2011 SIM 2SS/RS Vert
A friend had had an issue with a loose spark plug wire causing that message as well. Not sure about the "Why" it causes it, but that is the first thing that I would check.
GnyaTek is offline   Reply With Quote
Old 03-03-2013, 07:29 PM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Did you do a dyno pull before packing it away? That will sometimes make that pop up. Usually goes away after a few miles of driving. Shouldn't be a big issue as long as it goes away once you get it on the road. :wink:
9/26/09 Took delivery!
Old 03-03-2013, 07:35 PM   #8
Crashnburn7
no dyno, ever...yet
Old 03-03-2013, 07:39 PM   #9
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Hmm... You could plug in the SCT tuner from Ted and do a code scan. See what pops up and clear the code. If it pops back up then there might be something wrong. I would say it'll most likely clear itself out but you wont know till you get it on the road.
Old 03-03-2013, 07:45 PM   #10
Crashnburn7
I thought that only checked CEL codes
Old 03-03-2013, 07:48 PM   #11
GnyaTek
GnyaTek's Avatar
Did ya check all the spark plug wires yet? Seriously ... this has caused this issue for multiple folks.
Old 03-03-2013, 07:51 PM   #12
Crashnburn7
I will tommorow, no electricity in my garage.
Thanks for your help, Ill let you know
Old 03-03-2013, 07:52 PM   #13
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Mine does this same thing on occasion. I just ignore it and it goes away. I tried taking it to the dealer but we all know how those trips go. Intermittent issues=fun times.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 03-03-2013, 07:54 PM   #14
biggerisbetter
lll
i dont know why the spark plug wire causes it i think it is something to do with limp mode but it does. just check them when u can i bet thats what it is.
PERFORMANCE
APPEARANCE
