ADM PERFORMANCE
Old 03-03-2013, 07:06 PM   #1
Morpheusxeno
Morpheusxeno's Avatar
Drives: 2010 Camaro 2LT
Clutch Drop Sound
When pushing in the clutch in first gear quickly and low RPMS (1400-2000) I hear this sound of something in the transmission dropping, Is this normal ? it sounds like a golf ball being dropped inside a thick metal box. Usually bounces a few times it sounds like.
Morpheusxeno is offline   Reply With Quote
Old 03-03-2013, 07:11 PM   #2
Mutant Racer
Mutant Racer's Avatar
Drives: 2015 2LT Torch Red C7 Stingray
I hear it before I back in to my garage. I do believe it is normal.
Mutant Racer is offline   Reply With Quote
Old 03-03-2013, 08:15 PM   #3
Sblann
Drives: 2013 camaro ss
The dealer gave me bullentin number 03-07-29-004h manual transmission operating characteristics it goes over basic information, cold operation, gear rattle,neutral rattle, backlash, shift effort, non synchronized gears. So with all that said no matter what noise your car is making they have an excuse for it in this document. I think it's unacceptable for a 40 thousand dollar car to make this sound.
Sblann is offline   Reply With Quote
Old 03-03-2013, 08:38 PM   #4
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
It's not the car's fault. Like Comrando said, it's driveline slack. It means the car isn't being driven well...
Don't push the clutch while the driveline is loaded. Consider it a message from your car to you!
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 03-03-2013, 08:57 PM   #5
CamaroSS_RJS
CamaroSS_RJS's Avatar
Drives: 2010 Camaro SS/RS
Yeah, mine does the same thing.....in first gear......no matter how gentle you try to be, it just makes that sound.
CamaroSS_RJS is offline   Reply With Quote
Old 03-03-2013, 08:58 PM   #6
CamaroSS_RJS
Backing up I hear another type of sound from the brakes......it's not the clutch....only does it in reverse. Need to find out more about this.
Old 03-03-2013, 09:02 PM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2013 Sonic Hatch
It doesn't matter if it's 40,000, or 1,000,000...a manual transmission is operated by the driver. And is subject to human error.
In first gear, with such a tall overall ratio between the engine speed and the wheels...there's a little slack in the drivetrain. Some talk about gear lash when referring to it.
Very normal...with practice and purpose, it can be avoided.
Old 03-03-2013, 09:02 PM   #8
CyberPunk223
Drives: 2012 LS Camaro
Try shifting smoothly and a bit slower. and try pushing the clutch all the way down when making the 1 to 2 shift (i assume this the 1 giving you trouble), what happens to me sometime is that I will shift before pushing the clutch down and you get a thunk (this is you pulling the tranny out of gear with the clutch still engaged), or sometimes I just dont push the clutch down enough. happens a lot if your not careful on the 1 to 2 shift.
CyberPunk223 is offline   Reply With Quote
Old 03-03-2013, 09:07 PM   #9
thahemp
Geek
thahemp's Avatar
The drivetrain has an amount of slack in it. When it is loaded the slack is taken up. If you disengage the transmission from the engine while it is loaded, everything will spring back and oscillate. That is what you're feeling/hearing. If you match the input RPM to the output RPM and release driveline pressure slowly, it will not make the noise.
I usually piss my car off when I'm pulling into the garage. I used to do it a lot in parking lots or anywhere slow driving was required. You just have to learn to deal with all of the different loaded drivetrain scenarios and knock them out one at a time.
x = ~x
Old 03-03-2013, 09:51 PM   #10
Mutant Racer
What do you guys mean by being gentle? To go from 1st to reverse I have to stop my car and I'm already creeping down the alley to get to my garage. Right before I stop I press in the clutch and you'll hear that little drop sound.
Are you guys talking about something else?
Old 03-03-2013, 09:59 PM   #11
Mr. Wyndham
It sounds like you might be leaving it engaged too long. Experiment letting off the clutch sooner. Sometimes, you can load it, erm..."backwards"? If the engine sputters down below normal idle speeds it will want to spin back up, and so when you release the clutch just before a stop it might make a little rattle sound as it releases that tension.
I discovered that at stoplights...I'd wait just a little too long to depress the clutch at a traffic signal. I don't know if that is your issue or not, though.
Old 03-03-2013, 10:10 PM   #12
Sblann
Had a 78 civic, 1969 camaro, 1989 Subaru, 1986 mustang gt, 1980's ford truck and a 1976 scout international all with manuals and none of these made this drive line slack as loud as my camaro is now. Maybe we're talking about different things but my car is a loud clunk and i did drive other new 2013 camaros from other dealers, ( 3 to be exact) they all did make the same noise but it's a slight clunk and I could make it happen or I could stop it from happening depending on how I drove them I get that (those were tolerable and if mine was like that i wouldnt have a problem with it) but mine is not even close to the sound those made. it is alot louder and is harder to not make it happen than in the other cars. Dealer just told me some are louder than others and that he could replace transmission but i may get a louder one and he didnt even take it in and look at it (same thing for another dealer i went to, he just printed me out a bulleton about it) don't think it would be possible to get a louder one than mine. Any suggestions would be appreciated
Old 03-03-2013, 10:14 PM   #13
SolomonSS
SolomonSS's Avatar
Drives: 2013 Camaro 2SS RS M6
I experience this too but never thought there was anything wrong.
I get that "knocking" sound if I slow down and engage the clutch too soon or too quickly while coming to a stop. If I begin pushing the clutch in below 15 MPH while coming to a stop there is not any knocking.
2013 Camaro 2SS/RS M6
Black
NPP Exhaust
SolomonSS is offline   Reply With Quote
Old 03-03-2013, 10:14 PM   #14
Mutant Racer
Ok I'll give that a shot. When I shift to reverse it should be more seamless? I might be waiting too long to make sure I don't end up in 5th instead of R.
