HeadlightArmor
Old 03-03-2013, 09:49 PM   #1
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
MS-8 set up question
ok front speakers are hertz 165 XL components. tweeters and mid speaker are going through the cross over supplied. rear speakers polk mm 691 6x9 also using the suplied crossover that came with them. on the set up menu on the ms-8 it says one way 2 way and 3 way. one way if full range and 2 way are a mid driver and tweeter. how would i set this up on my front channels? I assumed 1 way becouse the mid and tweet are seperate. but they do both get their power from the cross over. ??? the rear only have a one way or full range option but to be sure ????..
then the book talks about hertz for the front speakers has a recomended setting of 50hz through 10,000khz. and the rear sugest 100hz
mgoodbar is offline   Reply With Quote
Old 03-03-2013, 10:13 PM   #2
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
Your front are 1 way because you used the crossover.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Pioneer DEX-P99RS * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 03-03-2013, 11:09 PM   #3
mgoodbar
Drives: 2010 L99
ok next question. The MS-8 did not like the 2 way setup i put in it and now no longer has any output. Im going to give it up for a wile and try again later. I hope i did not mess this thing up??? the speakers came on and i got to the check your work part. I turned up the volume some and it just quit . the power light and everything is still on and it acts as if nothing is wrong with it, but no output. i reset it and started over from scratch. the speaker came on but at a much lower volume and then it cut right off.. i was in the same mode check your work...
Old 03-03-2013, 11:31 PM   #4
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
no, I dont think it messed anything up. Just have to erase to default and start over
DraggnFrameGMC is offline   Reply With Quote
Old 03-04-2013, 12:03 AM   #5
darkrider01
So you're running head unit to your MS-8 via ******** FARK harness via RCA's, correct?
Head unit -> FARK harness -> RCA cables -> MS-8 -> RCA cables -> JL Amplifier?
Old 03-04-2013, 12:20 AM   #6
mgoodbar
Drives: 2010 L99
no I dont have the ******** harness. I used the wiring diagram and wired in a 4 outputs or RCA jacks... im using channel 1 and 2 on the MS-8 fed from the factory radio.
Old 03-04-2013, 04:05 AM   #7
mgoodbar
Drives: 2010 L99
That did the trick. I set on on 1way and it works great. man this thing really clears out all the crap and gives a clear clear.. output..
Old 03-04-2013, 04:15 AM   #8
mgoodbar
Drives: 2010 L99
its a work in progress
:bump2:
Old 03-04-2013, 04:22 AM   #9
mgoodbar
Drives: 2010 L99
im still waiting on my slash 300/2 too get here. I hope this week so i can get the amp rack made and installed by next weekend I need to take the doors back apart and check out the speakers. if ya look in the 3rd picture down youll see a bit of white stuff on the speaker. thats were the rubber outer ring and the inner, cone started to come apart. IDK i guess Hertz got stingy with their glue.. no big deal but im still gona send them in.. I have a bit of touch up work on the speaker grills to do... then im gona be looking at a sub.......... dont tell the wife looking at one now
Old 03-04-2013, 10:25 AM   #10
darkrider01
LOL! I'll make ya a good deal on Rockford Fosgate T1D215 with a ******** box if you want to come get it. Shipping would probably cost ya more than gas.
Glad everything is sounding good for you man!
Old 03-04-2013, 07:01 PM   #11
mgoodbar
Drives: 2010 L99
lol,, I bet your right about that. My brother inlaw has one of them. that thing weighs a ton.. he had to laminate 2 pices of one in MDF together to get 2 in thick. with bracing and 4 in screws he kept blowig his box apart... he used gorilla glue I dont remember the exact fosgate amp, but if i remember right it was 1200 bucks and like 2000 rms..
not sure.........
Old 03-04-2013, 08:57 PM   #12
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Are you getting a shutdown pop with your MS-8?
I am, and nothing I have done to try and stop it has been successful. I'm really considering pulling the MS-8 out of my system, since my HD900.5 never popped.
jeepguy_1980 is offline   Reply With Quote
Old 03-04-2013, 09:52 PM   #13
mgoodbar
Drives: 2010 L99
yea kinda weird . I never had a pop with my front channel till now?? my slash never poped at all now it does?????????????????
Old 03-04-2013, 10:11 PM   #14
darkrider01
The head unit is the cause of the pop. There are only 3 ways that I know of that can get rid of it.
1. Use the cigarette lighter as your remote turn-on - I have not tried this, but I hear this works.....
2. Replace your stock head unit with an aftermarket unit.
3. Use a Metra trigger for your remote.
Since both of you guys have it, do you have your JL amps using the same remote turn-on as the MS-8, or do you have the MS-8 controlling the remotes for the amps?
