HeadlightArmor
Old 03-04-2013, 08:39 PM   #1
cuffnstuff1
Drives: Hearse
high low octane timing degree
Ok I have a ultra gauge that tells me the timing degree while i drive.
how would i use it to tell if im in low octane mode or high octane mode.
The dealer and I put 87 in my 2012 2SS/RS, I then let the tank run down to 4 gallons and filled up with 90 (93 not avalible) I did the fuse pull for 2 hours and I did not see a change with my timming degree numbers.
Am I looking for high degree numbers when its in high octane mode and low number even in negative with low octane mode, or vise versa?
I hope theres someone that could answer this.
cuffnstuff1 is offline   Reply With Quote
Old 03-04-2013, 10:30 PM   #2
gmen09
gmen09's Avatar
Drives: 2010 Camaro SS ls3
I would be interested to here any responses
gmen09 is offline   Reply With Quote
Old 03-04-2013, 11:23 PM   #3
cuffnstuff1
Drives: Hearse
HMMMMM wonder if anybody really knows, theres so much talk about the fuse pull
Old 03-05-2013, 12:57 AM   #4
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
How did you drive your car when you had the tank of 87 in it? If the car spent most of its time idling or just cruising around, chances are your knock sensor did not pick up enough ping/knock retard to set the ECU into low octane mode, unless you were going WOT for a bit and got the revs up, it most likely didnt make a difference.
Generally speaking though, if its in low octane mode, you will have less overall ignition timing (lower numbers) throughout the RPM range then you would if it was in high octane mode (high numbers).
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 03-05-2013, 06:53 AM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The stock high octane timing will run mid to high 20's, low octane will be 5-8* lower.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 03-05-2013, 08:17 AM   #6
cuffnstuff1
Drives: Hearse
so is this at idle or WOT
Old 03-05-2013, 08:23 AM   #7
Motion427
Drives: 2010 2SS/RS Red Jewel L99
At WOT.
Motion427 is offline   Reply With Quote
Old 03-05-2013, 08:28 AM   #8
cuffnstuff1
Drives: Hearse
Originally Posted by Motion427 View Post
At WOT.
Ok then i am in high octane level. it running at 28-30. the two tanks or 87 octanine was real lighlty ran interstate bringing it home at some in town, did not want to open it up to much to break it in.
Old 03-05-2013, 08:55 AM   #9
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Unless you had a spread sheet of the high and low octane timing maps and were able to pick out the Cylinder grams per second and RPM to find the cell it is pulling from on both maps at the same time it would be nearly impossible to see while driving.
You would have to log then go back and review having all this data available at the same time.
Much Like I do while tuning.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
