HeadlightArmor
Old 03-04-2013, 08:46 PM   #1
11Huggerwhite
11Huggerwhite's Avatar
Drives: 2013 Camaro SS supercharged
Straight Pipes
I'm picking up my car tomorrow, after getting the cam and headers put in. I want it to be really loud but I don't know if the straight pipes will make the dual mode exhaust sound like crap. I run with the exhaust flaps always open also. I have TSP 2" headers and a TSP 235/239..639"/623" camshaft now with high flow cats. Do you think the straight pipes will ruin the sound or should I just do the straight pipes? Thanks!
11Huggerwhite is offline   Reply With Quote
Old 03-04-2013, 08:57 PM   #2
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I had straight pipes on my last car but without the dual exhaust... I just ordered my headers so I am in the same boat as you... I would imagine it should sound the same right? i believe the only difference is one is louder than the other..
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 03-04-2013, 10:12 PM   #3
11Huggerwhite
I think I'm going to do it and hope for the best.
Old 03-04-2013, 10:19 PM   #4
the barber
the barber's Avatar
Drives: 13' Sw 2ss Ls3
I'm debating on how the same setup would sound also!!
the barber is offline   Reply With Quote
Old 03-04-2013, 11:00 PM   #5
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Why would it sound any different?
If you run the dual mode exhaust always open, then you are essentially already running straight pipes, as one of the tips on each side completely by-passes the muffler.
I think you're going to waste money for nothing. Why did you pay for the NPP/Dual mode exhaust feature if you're just going to remove it now? Doesn't make sense IMHO.
2012 Camaro 2SS/RS - LS3/TR6060: BTR Stage 4, 2" Long Tubes, 3" Exhaust, UDP, NEP OTR, Monster Twin-Disk, 3.91 Gears, Poly Diff Bushings, BMR Toe Arms, Poly Subframe Inserts, ZL1 Mounts, Arun Tuned - 475rwhp 443rwtq
3rdgen3 is offline   Reply With Quote
Old 03-04-2013, 11:11 PM   #6
1sikRS
Drives: chevy
Agreeed that's just wasted money
1sikRS is offline   Reply With Quote
Old 03-04-2013, 11:43 PM   #7
thirdleft152
thirdleft152's Avatar
Drives: 2013 2SS/RS LS3 - Summit White
Its probably going to be obnoxious, and not sound as good. I had a muffler delete on my car and recently got some LTs put on which removed the stock cat and res. I originally thought the same as you but after the shop put my LTs on and let me hear it i imediately had them put a cat-back 3" exhaust on.
Agree'd it is a waste of money. I'd stick with the dual mode exhaust. With LTs and cam its going to sound real good especially once you open it up.
ADM Race CAI - SW LT - Mangaflow 3" Comp - EE CC
ADM Tuned - 412 rwhp 406 rwtq
thirdleft152 is offline   Reply With Quote
Old 03-05-2013, 12:17 AM   #8
the barber
the barber's Avatar
I think the op and I are wondering if cat delete would make the exhaust sound louder or like crap
Old 03-05-2013, 12:40 AM   #9
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
In short, yes, a lot louder, especially on idle.
