Gen5DIY
Old 03-05-2013, 07:39 AM   #1
t&t moyer
It's all hers.
t&t moyer's Avatar
Drives: 2015 ZL1
Putting together a spare tire kit.
I want to put together a spare tire kit for my 1LE. I have a spare front wheel from my 2012 45th Anniversary SS and am trying to decide what size tire to use as a "happy medium" that'll work for the front & back for emergencies only.
t&t moyer is offline   Reply With Quote
Old 03-05-2013, 08:03 AM   #2
djm96z28
djm96z28's Avatar
Drives: 2012 Camaro 1SS LS3
I did the same thing for my 1SS. I bought the jack, lug wrench, foam container from the dealer. Also bought a used stock front rim from a member here and mounted a front tire 245/45/20 on it. It's the same diameter as the stock rear tires (at 275/40/20) so it will work on the front or back.
I got a Cooper Zeon RS3-S tire because it's non directional (same as Pirelli P-Zero), so it can be used on either side of the car. I keep the spare tire strapped down in my trunk at all times.
Sure you could do the same for a 1LE.
djm96z28 is offline   Reply With Quote
Old 03-05-2013, 10:34 AM   #3
MikeOD
Drives: 2010 M6 2SS
This is what matters most...different diameter in the rear will make a TON of heat in the differential, and can kill a posi in short order (just driving the car home or to the tire shop).
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-05-2013, 10:47 AM   #4
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
1LE Diameter wheel with tire is 27.8in
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 03-05-2013, 05:14 PM   #5
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
I've got a 20x10 ET TWS Nurburging with a stock size 285/35/20 Michelin Pilot Super Sport fits front or back. Spoke to a couple folks at Tire Rack...they confirmed that it would work on either side at highway speeds with no issue even though it has a designated direction. Not like it would be on there permanently, but would work in a bind with no issues at all.
Phdpsy is offline   Reply With Quote
Old 03-05-2013, 11:10 PM   #6
t&t moyer
It's all hers.
t&t moyer's Avatar
Drives: 2015 ZL1
I just want to make sure I find the right combo that measures up right and want to cover my bases on possible issue I haven't though about.
