Gen5DIY
Old 03-05-2013, 09:22 AM   #1
Harley Kidd
Drives: Black 2013 2SS/RS LS3 M6, Hurst
Texas Speed Heads on 2013 2SSM6
I am fixing to order the 1 7/8" headers from Texas Speed. As my car has the new NPP exhaust I wanted to see if anyone else has put these heads on their car with the NPP exhaust and if there were any issues fitment or otherwise.
Harley Kidd is offline   Reply With Quote
Old 03-05-2013, 10:11 AM   #2
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
Drives: 2010 Camaro 2SS/RS/LS3/M6
I have the same headers, the clamps are cheap and don't seal completely. Suggest you get a wider clamp or just have someone weld them like I did. You will need 02 extensions. FYI, remove the sensors when you have the pipes off the car, much easier.
Texas Speed LT Headers with HF Cats, Borla ATAK Exhaust, MGW Short Throw Shifter, ADM CAI with Scoop, Elite Oil Catch Can, Mishimoto Aluminum Radiator, Pedders XA Coilovers, Mantic Twin 9000 Clutch, PFADT Solid Subframe Bushings, PFADT Front & Rear Sways, PFADT Upper Control Arm Bushing, PFADT Trailing Arms/Tie Rods, Whiteline Adjustable End Links, Whiteline Adjustable Lower Control Arms, Pedders Diff Bushings, Line Lock, ACC Side Markers, ACC Reverse Lights, Custom Tune from Nitrous Express.
Iroc2430 is offline   Reply With Quote
Old 03-05-2013, 10:20 AM   #3
11Huggerwhite
11Huggerwhite's Avatar
Drives: 2013 Camaro SS supercharged
Picking my car up today will post a video later if I can. Mine are 2" headers tho.
11Huggerwhite is offline   Reply With Quote
Old 03-05-2013, 10:33 AM   #4
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
In for the video
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 03-06-2013, 12:59 AM   #5
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
In for the video too!
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 03-06-2013, 05:38 AM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I would suggest you DO NOT weld your exhaust especially your headers. It will make it waaaay easier to work on just in case shit happens and you need to replace something in or around your exhaust. Then your gonna have a hacked up exhaust system. There are some good stepped clamps out there that you can get at NAPA and they won't leak. Just my .2
Old 03-06-2013, 06:29 AM   #7
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
+1 i have no problems with my clamps
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-06-2013, 07:35 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There are no issues whatsoever.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-06-2013, 09:31 AM   #9
Jason 98 TA
Drives: Camaro
Never had anyone complain about the clamps before!?!? Lots of guys like this style, I personally think they sill better than the thinner wide ones. I always thought the wide ones didnt squeeze good enough to seal anything!?!?!
Hi Terry!!
Jason 98 TA is offline   Reply With Quote
Old 03-07-2013, 03:20 PM   #10
11Huggerwhite
You will love them!
