Old 03-05-2013, 10:49 AM   #1
BossHogg
Mexican SS
BossHogg's Avatar
Drives: Black 2SS/RS
** Under Drive Pulley **
What's the big performance gain with this pulley? What's the pros and cons to it? And is one brand better than the other ?
Black 2010 2SS/RS...
Dyno Tune..
Volant Cold Air Intake..
Custom Installed Escort 9500 Ci Radar
Smoked Tail Lights-Reverse Lights -Front/ Rear Corner Lenses
Painted Bow Ties front & rear
Pacesetter Long Tube Headers
Magnaflow Competition Cat Back Exhaust....
Eibach Pro Lowering Kit
Painted Heritage Grille
1969 Camaro Emblems
Phoenix Gold I-Amp Sound System
22 inch Replica Wheels:
VMAX Ported Throttle Body
BossHogg is offline   Reply With Quote
Old 03-05-2013, 10:59 AM   #2
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Less parasitic loss from driving your water pump, altenator, ac and power steering at lower rpms. I'm not exactly sure about gen 5 Camaro's, but a 10% underdrive is usually good for 5-8 peak horsepower.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 03-05-2013, 11:00 AM   #3
willhe64
willhe64's Avatar
The downside is your ac is going to be 10% less cold, your altenator is going to put out 10% less amps etc...
Haven't heard of it causing any issues though.
Old 03-05-2013, 11:03 AM   #4
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I'm running the Fludampr 25% underdrive pulley. It has far superior balancing compared to the OE. The A/C pulley remains the stock diameter so the compressor rpm is not affected. You may notice a slightly tighter feel in the steering at low speeds. Charging system is normal. Others will claim that the alternator output is lowered. Totally false. The alternator is controlled by the BCM, output voltage is based on need.
LSX Camaro is offline   Reply With Quote
Old 03-05-2013, 11:09 AM   #5
BossHogg
Mexican SS
BossHogg's Avatar
Sweet. I think that's gonna be the next mod, I'm about to order my VMAX ported throttle body then the Pulley.... Thanks for the info....
Dyno Tune..
1969 Camaro Emblems
Old 03-05-2013, 11:09 AM   #6
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Is the steering really bad?
Nightmare2012 is offline   Reply With Quote
Old 03-05-2013, 11:10 AM   #7
BossHogg
Mexican SS
BossHogg's Avatar
Bc I noticed that their were 15% and 25% pulleys....
Dyno Tune..
1969 Camaro Emblems
Old 03-05-2013, 11:10 AM   #8
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
^^ This. I have the SLP 25% and have no negative side affects. I put it on the same time as a cam and headers, so I cant give you a performance gain for it, but people complaining about the A/C and charging system are crazy. I live in TX and last July my A/C almost froze my ass out of the car!!! I also have a 12" sub in the car. Still on original battery.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 03-05-2013, 11:11 AM   #9
BossHogg
Mexican SS
BossHogg's Avatar
Yea 376LS3 that's what kinda bothered me.. I also have a sub and amp in my car, I was just concerned...
Dyno Tune..
1969 Camaro Emblems
Old 03-05-2013, 11:13 AM   #10
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I didnt notice any issue with the steering....Anytime youre above an idle, the whole system is going to perform as if it was stock.
Old 03-05-2013, 11:30 AM   #11
LSX Camaro
LSX Camaro's Avatar
No the steering is not bad at all. It is slightly tighter at idle. For example when driving in a parking lot. To me it feels better. As stated above anything above idle will be totally normal.
Old 03-05-2013, 12:26 PM   #12
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Most put a pulley on with a cam swap and with the need for increased idle speed with the cam it offsets the powersteerings lowered speed.
Old 03-05-2013, 01:37 PM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If on a budget then a powerbond is good, if you got the bucks then get an ATI. I've had a pb for years and never had a problem.
Old 03-05-2013, 01:54 PM   #14
Bo White
Bo White's Avatar
I had a PB on mu 98 Z28 and it did fine.
