Old 03-05-2013, 05:20 PM   #1
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Tire Noise at 75 mph plus
Anyone else noticed this. Don't hear anything under 75, but then it comes on and build some as speed increases. Thought it was the exhaust note at first, but then realized it did not matter what rpm. Putting clutch in and rpms dropping to under 1000 you can really hear it.....almost feel it. As speed drops under 75 it goes away. Really annoying as I'm frequently on the interstate....not that I drive over 75
Phdpsy is offline   Reply With Quote
Old 03-05-2013, 05:27 PM   #2
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
All your pressures reading ok?
Old 03-05-2013, 05:35 PM   #3
rjdapilmoto
DAP-ONE [COTW - 12/23/13]
rjdapilmoto's Avatar
Drives: 2010 - 2SS/RS IOM
What he said. Check your tires and make sure your readings are good. If you've got alot of miles on them already, it may be time to get new ones. That was my case... Good luck..
rjdapilmoto is offline   Reply With Quote
Old 03-05-2013, 06:27 PM   #4
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
780 miles, pressures all read 35-36 after driving a few miles. Can't isolate the sound to any given corner. There is no pulling to any side or vibration like you might feel with a poorly balanced wheel/tire. All original weights from initial balancing are in place....hmmm
Old 03-05-2013, 06:38 PM   #5
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
should be 32
cornerspeed92 is offline   Reply With Quote
Old 03-05-2013, 06:52 PM   #6
Cooley
Cooley's Avatar
Drives: 2013 2SS 1LE
I've heard it too...kind of a roaring sound which increases as you gain speed. You can feel it as well as hear it.
I believe it to be a combination of the tires grabbing the road and the aerodynamics of the 1LE. I enjoy the sound, it puts a permagrin on my face.
Cooley is offline   Reply With Quote
Old 03-05-2013, 06:57 PM   #7
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Originally Posted by cornerspeed92 View Post
should be 32
They are 32/33 cold..they get up to 35/36 before long.
Old 03-05-2013, 07:00 PM   #8
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Apparently others just don't drive fast enough to test it out!
Come on guys, go grab a brief stretch of highway, turn the radio off, and make a quick run 60-85 or so and report back
Old 03-05-2013, 07:01 PM   #9
cornerspeed92
Yes my bad
Old 03-05-2013, 07:19 PM   #10
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
The specific pavement surface and it finishing may have something to do with it.
As may the camber settings for any or all of the wheels. Keep in mind that the G.2 Goodyears are an asymmetric tread pattern which might not sound the same at all values for operating camber. (You can measure static camber yourself by various DIY methods, which should be pretty close to what the car runs at out on the highway)
Keep also in mind that the car may not actually have the OE-preferred camber settings. The factory defines a range of what's acceptable for a reason.
Norm
Norm Peterson is offline   Reply With Quote
Old 03-05-2013, 07:55 PM   #11
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Norm
It does it on any road I've been on at 75+ from the first drive home from the dealer on the interstate. . I'll be having an alignment done in a week or so for an upcoming track event, so I will have them measure what it is presently in "stock form" to see if that may be a factor. Just never had this before on any cars. First car with the G2s for me, but a local ZL1 guy never had this noise at any speed on his stock G2s.
Thanks for the feedback. My main concern is that it is not something that will be a safety issue at high speeds. I will regularly see 120-135 on the track (road course, not drag strip). Not a good time for surprises.
Old 03-05-2013, 09:52 PM   #12
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
This happened on my last car... there was also a slight vibration above 90. I had the dealer road force balance my tires and I was good to go. No issues on the 1LE.
tramtwo is offline   Reply With Quote
Old 03-06-2013, 07:17 AM   #13
Norm Peterson
Understood completely (also the part about 20 minutes > 12.x seconds).
Good luck and have fun.
Norm
Old 03-06-2013, 09:32 AM   #14
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
I would have he tires road force balanced. Is the steering wheel vibrating?
b4z is offline   Reply With Quote
