Caryle Racing
Old 03-05-2013, 11:54 PM   #1
air1kdf
Drives: his 45th SS everywhere
Nice improvement
I put on an Fastlane Pipeline on my completely stock 2012 SS. Like everybody else I looked at Jannety's excellent tests, and the GM High Tech article. In addition I had an 02 Z06 in the past that I put a vararam on and it really woke that car up. Along with a Lightning that I had a box similar to the CAI with a huge cold air vent. And a an 01 Cobra with just a K&N. All of them were a huge improvement.
I wanted to point out that I felt that the magazine article wasn't fair because of the difference in temperatures. But that is also a real test, which means more to me than a dyno pull. What I really looked at was temp delta after the run compared to ambient. This would show that stock sucks hot air and most of the others were an improvement. This coincides with improvements that others are seeing with different intakes.
I'm running without a tune, but did reset the LTFT's, after a run. Interesting that at 4650 hz and above the STFT were significantly increased, which also shows higher density air delivered. On the street, it showed 0-2 degrees above ambient. When I punched it traction control took on a whole new meaning. I can't believe how much more torque is being delivered. I'll run it for a tank to let the LTFT's settle (which were all high because of the cold air with a stock intake), then log the KR and fuel trims.
So in the end I just wanted to say that I think that most of the intakes probably do very well compared to stock in actual driving conditions. For those on the fence with an intake. Do it, and enjoy more power.
air1kdf is offline   Reply With Quote
Old 03-06-2013, 05:09 PM   #2
striker1703
striker
striker1703's Avatar
Drives: 2010 Camaro 2SS
Congrats on your intake install and new found power.
striker1703 is offline   Reply With Quote
Old 03-06-2013, 07:14 PM   #3
air1kdf
Thanks Striker... So how do you like the vararam compared to the pipeline?
I also forgot to mention that it sounds much nicer than stock. When you hammer down, you can hear the engine a little better.
Old 03-06-2013, 09:54 PM   #4
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
I noticed the exact same thing with my pipeline. I actually have a weird misfire problem with the pipeline + ported TB and traction control on. If I punch it... it just hesitates and makes no power. With the TC off, on the other hand, it runs perfectly. The power gain is very apparent. Really nice upgrade for the money.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 03-06-2013, 09:55 PM   #5
thahemp
Geek
thahemp's Avatar
BTW. Add the 3" exhaust note, and I'm down to 4/32" after 10,000 miles.
x = ~x
Old 03-06-2013, 11:23 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Vararam has been on mine for about 2 years now not a problem.
Old 03-07-2013, 02:42 AM   #7
striker1703
striker
[QUOTE=air1kdf;6254004]Thanks Striker... So how do you like the vararam compared to the pipeline?
I'm not quite sure yet. At first the Vararam felt no different than the pipeline intake but that was expected within the first few miles. It might be mental but after 100 or so miles the car seems to have woken up and adjusted to the Vararam. The car is responding well while on the highway at higher speeds. I purchased the Vararam with the sole purpose to try it out at the drag strip this Friday so I should be able to tell the difference then.
