SDTW Custom Wheels & Tires
Old 03-06-2013, 10:59 AM   #1
Tweiten
Tweety
Tweiten's Avatar
Drives: 2010 Camaro 1LT RS
Question Loudmouth 1 is too loud. What can I do.
So a few days ago I got my LM1 installed on my V6 Camaro. But, it's WAY TO LOUD. Mostly to loud in the cabin. What can I do to make it so it's not as loud in the cabin. Can I add something or should I just buy a new Axle-back exhaust.
So again, I like this exhaust but I don't like how loud it is when I'm in the car with the windows up...
Tweiten is offline   Reply With Quote
Old 03-06-2013, 11:05 AM   #2
jamison90
Drives: 2014 Mustang GT
a magnaflow resonated xpipe will help quiet it down.
http://www.apex-speed.com/magnaflow-...ipe-11386.html
Originally Posted by Jorge_ss View Post
Hola! Abra alguien q hable español? Tengo una pregunta pienso cambiarle a mi camaro ss 2013 el sistema de escape (headers,xpipe,mofles,etc) solo que iré paso a paso que m recomiendan empezar? Con unos mofles magnaflow o meterle xpipe y quitarle catalizadores? (Recuerden q en México no es ilegal)
Saludos a todos y es el mejor foro de camaro
Originally Posted by firedrop View Post
yo quiero taco bell
jamison90 is offline   Reply With Quote
Old 03-06-2013, 11:07 AM   #3
Linker239
Linker239's Avatar
Drives: 2010 VR 1LT RS
Get a magnaflow resonated x-pipe put on, it will cut the rasp and a slight bit of drone , however it will make your set up overall quieter. Another option to kill drone is to get some J pipes put on.
Mods: Black Bowties, Thin Black Rally stripes, Roto-Fab intake,Cherry Bomb Extreme, Doug Thorley Shorty Headers, Magnaflow Resonated X pipe, Quads, and more to come.
Linker239 is offline   Reply With Quote
Old 03-06-2013, 11:08 AM   #4
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
Yep, that's about your only option besides getting a new setup. I swear I've seen the x-pipe for lower than that somewhere... maybe not...
awfarley is offline   Reply With Quote
Old 03-06-2013, 11:11 AM   #5
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Since your main complaint is with the windows up that leads me to believe you are hearing drone. The best way to offset the drone will be with a set of J-Pipes. J-Pipes will be better then an X-pipe in your case IMO.
FSP tuned: 377/389
Old 03-06-2013, 11:11 AM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Amazon sell it cheaper. If I'm not mistaken it should be about 95 on amazon but I could be wrong.
Proud owner of litho #179 Click Picture for Build Thread
Old 03-06-2013, 11:18 AM   #7
Tweiten
Tweety
Tweiten's Avatar
Okay so i'm hearing magnaflow x-pipes or j-pipes. Which one?!?
Old 03-06-2013, 11:23 AM   #8
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
If its anything like the MRT V2 let it season in for a couple hundred miles and see if the droning lessens enough that you can tolerate it. Then decide on either The resonated X pipe or the J pipes.
The Bird is the word!
Old 03-06-2013, 11:25 AM   #9
Angrybird 12
If its only at one certain rpm range then go with the J pipes, if its all the time then maybe the x pipe. Or you may end up doing both.
Old 03-06-2013, 11:28 AM   #10
GotGame55
Haters gonna hate?
GotGame55's Avatar
Drives: '04 Chevy Dirtymax
Just put in some ear plugs while driving. Problem Solved.
'04 CCSB Duramax
GotGame55 is offline   Reply With Quote
Old 03-06-2013, 11:31 AM   #11
Tweiten
Tweety
Tweiten's Avatar
I've tried turing the volume on the radio up to 45 and i can still hear it sometimes..
Old 03-06-2013, 11:33 AM   #12
Tweiten
Tweety
Tweiten's Avatar
What would be the effect of doing both? Its mostly around 1000-3000 rpms when i get annoyed of hearing it.
Old 03-06-2013, 11:34 AM   #13
GotGame55
Haters gonna hate?
GotGame55's Avatar
My muffler delete isn't even that loud...I can cruise at 40 in 5th gear at volume 10 and bearly hear it.
'04 CCSB Duramax
Old 03-06-2013, 11:40 AM   #14
Angrybird 12
The j pipes are usually tuned to one resonate frequency, and lose their effectiveness at other rpm ranges. The XPipe will be effective across the entire range but more to tone down the entire system. So I would do one then if not satisfied with the results do the other. The choice is up to you and sound quality is a subjective thing. What is annoying to one person sounds good to someone else.
Good luck.
exhaust
