B&M Racing
Old 03-07-2013, 11:43 AM   #29
Tweiten
Tweety
Tweiten's Avatar
Drives: 2010 Camaro 1LT RS
I was just thinking that maybe if I just added a muffler it would help? Would it? Instead of adding j or x pipes could i just add a mangaflow muffler or something?
Or would it still be better to do a j or x pipe?
Tweiten is offline   Reply With Quote
Old 03-07-2013, 11:46 AM   #30
Tweiten
Tweety
Tweiten's Avatar
Sorry if I sound newbie but this exhaust stuff is still fairly new to me..
Old 03-07-2013, 11:49 AM   #31
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Adding a muffler would definitely help but that would mean removing the loudmouth 1. If you're fine with that, and want a quiet exhaust, borla or magnaflow are the way to go. Everyone suggests the magnaflow x-pipe (which is basically a muffler) or the j-pipes because that's what you can do without removing the slp lm 1
Old 03-07-2013, 11:51 AM   #32
Tweiten
Tweety
Tweiten's Avatar
Alright so I'm thinking maybe ill just add the magnaflow x-pipe... You guys sure this will help with the drone and vibration?
Old 03-07-2013, 11:53 AM   #33
lscamaro
lscamaro's Avatar
The x-pipe will eliminate any rasp you may have and help drone some
Old 03-07-2013, 12:00 PM   #34
C586
Drives: 2011 Camaro LS
Originally Posted by Angrybird 12 View Post
If its anything like the MRT V2 let it season in for a couple hundred miles and see if the droning lessens enough that you can tolerate it. Then decide on either The resonated X pipe or the J pipes.
He got a muffler delete. No mufflers at all.
To the OP. The best thing to do is to get a new axle back. Even with a resonator of any kind unless you add a bunch of then its still gonna be bad. If you get a new axle back it will be alot simpler and lighter.
C586 is offline   Reply With Quote
Old 03-07-2013, 12:02 PM   #35
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
I know that now it's been mentioned several times since I posted that reply.....
The Bird is the word!
Old 03-07-2013, 12:08 PM   #36
KMPrenger
KMPrenger's Avatar
11386 is the magnaflow part number you want. It is a dual in dual out muffler with a perforated X inside. Intall it far up the exhaust closer to where the pipes come out of the cats. Basically where the stock H pipe would be.
This will help a lot....it has been done many many times.
Old 03-07-2013, 01:44 PM   #37
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
I would have simply gone with the LMII. There are mufflers and while there is a slight drone at highway speed, it's nothing compared to the muffler delete. Love my LMII. Loud when I want to get on it, and not obnoxious when I want to be a bit more covert.
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 03-10-2013, 01:44 PM   #38
Tweiten
Tweety
Tweiten's Avatar
New idea. (cant remember if I've said this before) What about LM2 Mufflers with the Magnaflow x pipe?
Old 03-10-2013, 02:03 PM   #39
lscamaro
lscamaro's Avatar
If you're thinking about using the magnaflow x pipe anyway, why not buy that first and put it on your current setup if you don't like it then, then spring for the LM2. But I think the LM2 and the x-pipe might be exactly what you're looking for
Old 03-11-2013, 03:21 PM   #40
Tweiten
Tweety
Tweiten's Avatar
Yeah maybe..any idea how much it would cost to install an x-pipe? Just the axle-back alone cost me $95. I would do it myself but I do not have the tools or the knowledge.
Old 03-11-2013, 03:33 PM   #41
lscamaro
lscamaro's Avatar
The x-pipe would probably be 1 to maybe 2 hours of work tops. It's really just 4 cuts and weld. Not that hard at all really.
I'm sure if a shop really wanted to get it done quickly, they could do it in 30-45 minutes since they have the right tools
Old 03-11-2013, 05:05 PM   #42
Tweiten
Tweety
Tweiten's Avatar
What about the mufflers? What would those cost to install. Also, I can't seem to find the mufflers online. I need them for the V6 2010 Camaro.
exhaust
