Old 07-05-2013, 05:53 PM   #267
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Like that setup. That scratch looks terrible.
Sent from my SAMSUNG-SGH-I317
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 07-06-2013, 04:25 PM   #268
butters
It's not the batmobile!
butters's Avatar
Drives: 2010 Camaro SS L99
whoops, had the silly thing backwards.
the pump was pushing oil back into the turbo instead of sucking it away. the return line was bone dry. turbo would have blown up eventually.
no words...
butters is offline   Reply With Quote
Old 07-06-2013, 04:28 PM   #269
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Originally Posted by butters View Post
no words...
I do. A question actually. Are u sure someone who was blind didn't make those welds?
Old 07-06-2013, 04:42 PM   #270
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
no words...
WTF is it?
Sent from my SPH-D710 using Tapatalk 2
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 07-06-2013, 07:38 PM   #271
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Originally Posted by GretchenGotGrowl View Post
WTF is it?
Original SUPER CHILLER Since 2009
Original XTREME CHILLER Since 2013
FACEBOOK 727 656 1422
Email Orders and Inquires
TrekGTO is offline   Reply With Quote
Old 07-06-2013, 07:52 PM   #272
TrekGTO
TrekGTO's Avatar
I have seen several sets of Turbos blown from a bad oil pump return system; I hope the damage isn’t already done! Did I understand correct this is a single Turbo build?
Matt can you explain the AGP Scavenge System, is that like an accumulator on the pump inlet?
Old 07-06-2013, 08:04 PM   #273
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
Wow those welds are just hideous! I would never tell a soul if I had made them.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 07-06-2013, 09:30 PM   #274
hunterv6
Always bet on Black
hunterv6's Avatar
What is it?
Old 07-06-2013, 11:33 PM   #275
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
It was the sump tank for the scavenge system... Except the pump flow was marked on the bottom of the pump, but the system was hooked up backwards so it never flowed through to the valve cover hookup. We are replacing that single piece of tubing because we no longer need the sump tank.
The AGP system consists of their AGP scavenge pump, filter (This is what you are probably seeing in the pics), lines, wiring, and timer box. Just have to adjust a couple of items since there is some charge tubing in the way and the fact that the AGP billet oil cap adapter is on the passenger side vs. the drivers side for the V8.
Matt @ FSP is offline   Reply With Quote
Old 07-06-2013, 11:47 PM   #276
Matt @ FSP
Matt @ FSP's Avatar
Just to further explain what butters had posted.. Look at the flow arrow marked on the bottom side of the pump, and see in the other picture that the feed line is going to the flow out side. Therefore it never reached the other side line it was bone dry.
Even though we have found this, we're still continuing with the AGP pump system, we know that it is tried and tested so we need something that works right off the bat. We'll see once that system is installed if that EFR turbo needs an oil restrictor, have to get up on WOT first to find out.
Old 07-07-2013, 12:12 AM   #277
TrekGTO
TrekGTO's Avatar
This is all so bad its Not Even Funny! I swear this reminds me of a car I just updated and memories from a couple years back!
Who took the Video and posted it of the car with all the smoke out back. I talked to some one that said an oil line blew off it 2 times when they were there! You know his mufflers are going to be full of oil and smoke for a long time. That makes it difficult to evaluate anything.
Old 07-07-2013, 09:41 AM   #278
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I have seen RX work before and I never had seen a configuration this Mickey moused ! Nobody was watching the shop when this was going on ?
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 07-07-2013, 09:54 AM   #279
GretchenGotGrowl
Matt:
That looks like the same pump I got from RX (I thought it was a aeromotive). We are running two EFRs and it has not trouble keeping up. You do not need restrictors for the EFRs (they say don't use any as they design them that way). The trick is to get the connectors of the pump below the bottom of the drain fittings for the turbo(s). I'll give you Aaron's number if you run into problems. I know he had to change a few things to get mine set up that way without it being so low as to chance hitting speed bumps and what not. Just PM me if you want his number of need any other info.
Old 07-07-2013, 12:54 PM   #280
KMPrenger
KMPrenger's Avatar
Sadly, I've seen pictures like this on others builds from there as well.
black, chevy camaro, lfx, turbo charger, turbo v6 camaro
