BeckyD@RodgersChevrolet
Old 03-06-2013, 07:16 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Any LFX folks spraying a 150 shot yet?
Tracks will be opening soon and I'm thinking about trying out a 150 shot anyone been this high yet. I have a tune for a 100 shot and run high test fuel usually 93 octane. Just asking before I put the pills in and give it a run.
CAI intake, RX catch can, N.O. Plate system, APEX air scoop, SOLO HFCs, JacFab ported manifold, upper intake isolator, Solo cat back Mach X system, 3.91 gears, Weld RT-S, 1 piece DSS driveshaft Stall convertor by:CIRCLE D, E85 & 80mm T/B
etmx183 is offline   Reply With Quote
Old 03-06-2013, 07:58 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Why don't u do 125 first?
Old 03-06-2013, 08:46 PM   #3
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
a 125 is what ran into the 11s on an LLT with skinnys up front and slicks out back.
Just a thought
KMPrenger is online now   Reply With Quote
Old 03-06-2013, 11:00 PM   #4
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
I'll say an LFX can handle the 150, then.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 03-06-2013, 11:25 PM   #5
lscamaro
lscamaro's Avatar
The LLT can handle the 150. I know of a local guy who sprays the 150
Old 03-07-2013, 09:12 AM   #6
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
150 shot
Indy Bumble Bee is offline   Reply With Quote
Old 03-07-2013, 01:08 PM   #7
etmx183
etmx183's Avatar
I don't have pills for the 125 only 150, but I have over a 100 runs on the 100 shot.
Old 03-07-2013, 01:12 PM   #8
lscamaro
lscamaro's Avatar
Oh ok well I would at least tell Vince you're going to be running 150 and have him draw up a tune for that as well. Just to be on the safe side. Like I said, there's a guy here spraying 150 of juice but I don't know how many times he's done it so don't know about longevity.
If you need to get a hold of Vince pretty quickly, it's better to email him direct.
Old 03-07-2013, 01:24 PM   #9
etmx183
etmx183's Avatar
Thanks for the replies.
Old 03-09-2013, 06:17 PM   #10
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2014 Summit White 2SS/RS 1LE
Any passes with the new rear axle yet?
2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, Elite Gen2 CC, ZL1 splash guards, ZL1 pedals, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's on HoosierStone Tires, Previous Car: 2012 Black 2LT/RS, Fully 1LE swapped
Wichita Region SCCA Autocross #23 FS
ICTsccaCamaro is offline   Reply With Quote
Old 03-10-2013, 10:53 AM   #11
etmx183
etmx183's Avatar
No runs yet, still waiting for an updated tune from Vince since I did a lot of changes with the diff also. Been two weeks still waiting. Don't want to take a chance with the air scoop and solo HFCs added and hurt something. Than after some motor runs I'll try to get an updated tune for the 150hp spray.
Old 05-07-2013, 10:35 AM   #12
speeddemon69
Drives: 2012 45th anniversary
I know it's a little bit out of the way but how much would a stock lfx handle?
speeddemon69 is offline   Reply With Quote
Old 08-10-2014, 12:24 AM   #13
garvyf22
Tonkaracing
Drives: 2013 2LS RED CAMARO
Bump
garvyf22 is offline   Reply With Quote
Old 08-10-2014, 11:05 AM   #14
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
About 500rwhp from what I've read. Things start breaking at that point.
Mods:
Roto-Fab Intake, WW Reservoir kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness.
