sjm autoprod
Old 03-07-2013, 11:28 AM   #1
Wasp
Wasp's Avatar
Drives: 2011 Camaro Victory Red 2SS/RS
Speedometer Recalibration $
How much does it cost to get your speedometer recalibrated due to gears? (3.91)
A guy in columbia says he will do mine for $150, which is a lot considering i have to travel two hours.
How much do they typically go for? All I want is a recalibration, not a full tune.
2011 LS3 Bone Stock 1/4 - 12.841 @110.69
LS3 + CAI (no tune) 1/8 - 8.27 @ 89
Wasp is offline   Reply With Quote
Old 03-07-2013, 11:37 AM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
It really depends on Auto or Manual.
Manual is easy, and you have to consider there is usually licencing involved that adds to the cost of Labor.
Auto Not so Much, Every Gear up and down, every lock up point up and down, Every WOT shift RPM up and down, Every WOT Shift Speed Up and down in all three modes must be calibrated.
It is a ton of work on an Auto.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-07-2013, 11:39 AM   #3
Wasp
Wasp's Avatar
It's just a manual
Old 03-07-2013, 11:47 AM   #4
JANNETTYRACING
It's just a manual
Still a Fair Price.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-07-2013, 11:48 AM   #5
Wasp
Wasp's Avatar
Thanks for the feedback!
Old 03-07-2013, 05:23 PM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Camaro Corvette Tuner in Tampa
Either Manual or Automatic its easy to do in HP Tuners.
If your calibrator like me, I license vehicles to my interface with unlimited access by year and models. I have an unlimited interface for the GM V8 Cars I can calibrate from 1997 to 2013 through HP Tuners. The Camaro, Corvette, and GTOs are my high volume business vehicles, so what he's charging you isnt a bad price and shouldnt take more than 15 minutes.
For you Do It Yourself folks with HP Tuners, all you have to do is pull up the Speedo tab, Click Speedometer and you'll see two windows for current and new.
Enter your new tire size (if it changed or old size if it didnt) and your new gear ratio.
Click the auto scale transmission tables YES and click commit.
Manual no further adjustments needed and your speedometer will be on target.
For the Automatic guys, same thing and after you click commit, HP Tuners will automatically rescale all your shift points for you for the new tire size and gears.
If you dont like your old shift points with your new gears, Yes it will take the work Ted wrote about, but at least your 95% closer to your target and will save you hours of time.
Phil
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 03-08-2013, 01:18 AM   #7
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
Why don't you just get a mail order tune. Where in SC are you at. Why don't you PM me. I think I know who you are talking about.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 03-14-2013, 10:40 PM   #8
429
Drives: 2010 camaro ss
If you want to make the drive to Savannah, GA I can do it for you for the cost of credits in HPTuners ($100), along with any other minor changes you might want or need (Speed limiter, RPM limiter, skip shift, torque management delete, etc)
429 is offline   Reply With Quote
Old 03-20-2013, 04:07 PM   #9
Alvin@PCMofNC
Drives: 2010 IOM RSS
We calibrate speedometers locally and mail order for $50. Mail order tunes are $250. Dyno tunes are $400. We are in Mooresville NC which is just a touch north of Charlotte. Let us know if we can help you.
Alvin@PCMofNC is offline   Reply With Quote
Old 03-21-2013, 12:12 AM   #10
Tampa Tuning
I did a rear gear change on an automatic Friday. $75 to clean up is shift points after the install. He was a client from last year and I like to cut them slack on pricing for returning to me.
www.TampaTuning.com
Phil
Old 05-05-2013, 11:26 AM   #11
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
I have teds tune, changed from a stock 20 in tire to a 19 in with low profile tire. How much to get the speedo updated? Manual car. Would it be point less or even possible for me to go back to stock and have the dealer update speedo then reinstall tune or would the tune overwrite the speedo portion? Thanks I will also send an email to Ted.
carrs_crew is offline   Reply With Quote
Old 05-05-2013, 11:37 AM   #12
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Should be a quick fix for ted to do to your tune.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 05-05-2013, 11:51 AM   #13
SSMickey
SECC
SSMickey's Avatar
Your tune will over write the stock file. Your going to have to update the tune you have now. We did mine Friday night and it took all of 5 minutes to do. If your updating the tire size, measure the height of the tire installed on the vehicle with weight on the tire. DO NOT use the tire height published on line. A good example of this is the stock SS tire size is listed at 28.7, but in the stock tune file, it is listed as 27.79.
Old 05-05-2013, 11:58 AM   #14
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
Thanks for the info and advice, pm sent to Ted. I love teds tune!!
