HeadlightArmor
Old 03-08-2013, 09:51 AM   #1
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Port&Polish L92 Heads
Plan is to throw on a whipple 2.9L on my block. I will be getting forged internals when I do pull the trigger. Currently I want to get the heads ported and polished while I'm not using the car. Does anybody have the specs for this and how much material comes off the heads for a forced induction setup?
Thanks in advance
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 03-08-2013, 09:56 AM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
You may want to contact Richard at West Coast Cylinder Heads.
LSX Camaro is offline   Reply With Quote
Old 03-08-2013, 10:11 AM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
And I'd get the lighter Ls3 intake valves and an inconel exhaust valve for your FI set up IMHO.
Old 03-08-2013, 12:18 PM   #4
SC2150
And no polishing!!!!! except the exhaust ports to help carobon from forming.
Old 03-08-2013, 12:33 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
to your
Old 03-08-2013, 06:43 PM   #6
SPCBA
Drives: pleather and Chiclets
goooo west coast heads!
SPCBA is offline   Reply With Quote
Old 03-08-2013, 07:42 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^ I'm with him!^^^
Old 03-11-2013, 02:27 PM   #8
Jason 98 TA
Drives: Camaro
Give us a call we can help you put together a head combo that will work well for you. We can help you select valves, milling, chambers sizes, etc to meet your goals. Not to mention the cnc work is under a 1K & typically gains about 25rwhp on a na car & more under boost
Jason
Texas Speed
www.texas-speed.com
Jason 98 TA is offline   Reply With Quote
Old 03-11-2013, 03:15 PM   #9
Kelly@PCMofNC
Drives: 2010 RS/SS
Richard does great stuff.
We also have great results out of Advanced Induction in Concord, NC.
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
