Flowmaster Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Wash/Wash/Detailing and Cosmetic Maintenance Parts
Old 03-09-2013, 12:00 AM   #1
RonniesCamaroSS
RonniesCamaroSS's Avatar
Drives: 2011 SS camaro
WTB Foam gun
Have a pressure washer but dont know which piece I need to adapt to make it work or do they make one that works with a water hose?
RonniesCamaroSS is offline   Reply With Quote
Old 03-09-2013, 03:57 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There are two different foam guns. One for a water hose and one for use with a power washer. I have the water hose version and really like it. It's was inexpensive and provides lots of foam. If I had a power washer, i'd get that version for the shear volume of foam i've seen them do. Adapting it would depend on which connection you currently have. I'm not aware of what most PW's have for a connection but you should be able to easily adapt it. I know the Chemicalguys PW foamer comes with at least two adapters. If you know what connector you have, it shouldn't be hard to get the peice you need. I'm sure you could call CG, Autopia, Adams, or any good vendor and they could help you out.
PW version
http://www.chemicalguys.com/Chemical..._p/eqp_300.htm
Hose version. This Gilmore FM has lots of brass parts which I really like. It also has lots of adjustments but I just use the most dense foam possible and that's it.
http://www.amazon.com/Gilmour-75QGF4...re+foam+master
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-09-2013, 05:32 PM   #3
RonniesCamaroSS
Thanks man!
Old 03-09-2013, 07:49 PM   #4
axis
Search Ninja
axis's Avatar
Just so you know, many of the vendor sites sell the same guns with just a different logo on the bottle. Find the cheapest one and push the buy button. Some of the vendors have gun and product combo deals so you might want to check on that too. A few have additional feebie deals if you spend a certain amount of $$ on an order. If you get a gun/product combo, you'll be close to $100.
CG has a sixpack of Chubby towels with $100 purchase.
Halltech CF 102 fed
