ADM PERFORMANCE
Old 03-10-2013, 06:30 PM   #1
RBL
Drives: 2010 camaro 2SS
tvs2300 RX catch can help.
can somebody please post pics of proper routing of a RX catch can hooked to a tvs2300. I just changed my oil (3K interval) and went to empty my catch can and it was dry as a bone. Yes, it was closed correctly (spun all the way out). I was collecting some before my supercharger install but now im not collecting any, something seems funny.
www.lashwaymotorsports.com
2012 L99, whipple, Roto-Fab, Stainless Power headers, ZL1 fuel pump, cat delete.
RBL is offline   Reply With Quote
Old 03-10-2013, 06:38 PM   #2
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
It goes from the back of the drivers side valve cover to the inlet on the can. Then from the outlet on the can to one of the 3 vacuum inlets on the drivers side front of the tvs.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 03-10-2013, 09:53 PM   #3
t!mbo
t!mbo's Avatar
Drives: 45th 2SS M6
Maybe that will help you, different can, but you will get the idea...
I think that was someone from the forum... Thumbs up for doing that!
t!mbo is offline   Reply With Quote
Old 03-11-2013, 10:30 AM   #4
SC2150
Rear of drivers side valve cover to center (inlet of can) and outer of can to vac barb on blower (wilhead has it correct).
Old 03-11-2013, 11:21 AM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
SC2150 - So with the new style SLP TVS on a 2012 what kind of mounting bracket & check valve setup do I need?
Iam Broke is offline   Reply With Quote
Old 03-11-2013, 01:46 PM   #6
Jessika
Drives: Anything Blown
^^^ same as the standard magnuson.
Jessika is offline   Reply With Quote
Old 03-11-2013, 02:38 PM   #7
RBL
ok here is how mine is done which looks correct. Why in the hell am I not collecting oil?
Old 03-11-2013, 04:42 PM   #8
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
cant help on the can ,,,, but I would move the idler pulley closer to the belt tensioner pulley... that will put more tension on belt and prevent slippage
bmbbl be is offline   Reply With Quote
Old 03-11-2013, 05:04 PM   #9
RBL
It's nuts tight. We used a smaller belt then what came with the kit.
Old 03-11-2013, 05:33 PM   #10
willhe64
willhe64's Avatar
I'm getting less now too then before the TVS2300.
Here's what I'm thinking. When we were running without the Maggie, the barb was right on the valley plate and there was no baffling. Now we are pulling from the back of the valve cover and maybe there is better baffling there?
Old 03-11-2013, 06:08 PM   #11
SC2150
yes...better baffeling Will.
RBL, good job! All is correct.
Old 03-11-2013, 10:31 PM   #12
RBL
So basically my catch can is not needed at all now?
Old 03-14-2013, 07:37 AM   #13
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Hmmmmmm? It's my belief that it's needed based on what I've seen that collects inside these superchargers but , you make an interesting point .
UNRIVALED SS is offline   Reply With Quote
Old 03-14-2013, 11:47 AM   #14
bikerdan
BLOWNSS
bikerdan's Avatar
Drives: 2011 SUPERCHARGED Camero SS
I get at least 2 OZ every 1000 miles
2011 LS3 SS/RS, M6, Maggie TVS2300 - cog drive, CAI, ZL1 fuel pump, Autometer gages, BEHE Performance tune , boost and AFR gages, MGW shifter, SLP long tube headers with high flow cats, Flowmaster Pro ex., Pfadt trailing arms, toe rods & bushings, G-Force axles, American Racing wheels, 305 mm P zero on rear, Elite catch can, SLP hood, amp & sub.
bikerdan is offline   Reply With Quote
