Gen5DIY
Old 03-11-2013, 03:56 AM   #1
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
zl1 fuel pump stays running?
after shutting down vehicle fuel pump remains running. anyone exprience this? installed pump 15000 miles ago and problem has just accured. no changes made to vehicle recently. disconnecting battery for now til problem is solved. I have a 2010 ss with a supercharger thanks. follow up.... I see it has a second pump that pumps fuel from the other side of the tank. This might make more since this pump is running instead of the main pump that pumps fuel to the fuel rail. This pick up pump might be able transfer fuel to other side with the key off. So maybe the fuel level arm is stuck telling the pump to stay on. help if anyone has run into this problem.
lionssfan is offline   Reply With Quote
