Caryle Racing
Old 06-18-2009, 08:39 PM   #1
toehead93
Drives: 2014 2SS/1LE
Frustration!!!
After washing I have several fine scratches. I don't know if it was from the wash or from the drying?
I tried the absorber and I must be honest it is a complete POS. It doesn't absorb anything compared to the Zaino towels. It just scares me when I use it and I'm am pretty sure it caused a few of the scratches. There are however scratches where I did not use the absorber. I'm so frustrated because I take so much care in washing the car and this happens. I've never had this happen on my other cars.
I use a microfiber mit and rinse it thoroughly after I clean each section. Is the wash mit causing it or the drying towels?
First I need to solve my washing dilemma then I need to fix the scratches. What is the best way to fix the scratches?
I plan on Zaino'ing the car this weekend.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 06-18-2009, 08:43 PM   #2
piddlewink
Drives: 2lt Red jewel vin#6632
I use the microfiber mit and microfiber towels and seems to be ok.
piddlewink is offline   Reply With Quote
Old 06-18-2009, 08:51 PM   #3
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
I posted this at another thread and here goes:
Here's my take and I hope it helps some of you in maintaining your ride. You would be surprised how much good you can do your car's finish just by washing it. Aside from maintaining the oil and keeping a coat of wax or sealant on the surface, routine washing is the most beneficial treatment you can give your vehicle.
Armed with two bucket's with grit guards and hose, here are the proper steps to make car washing easier:
1. If possible, work in the shade, out of direct sunlight. Elevated paint temperatures cause the wash and rinse water to evaporate too quickly, increasing the likelihood of water spotting.
2. Start by preparing a bucket with clean water and wash the wheels first with a proper wheel wash and brushes too. This prevents you from splattering cleaners, dirt and brake dust on already cleaned panels.
In addition to oily, road grime, wheels get coated with black, metallic, dust particles every time you brake. Car wash shampoos alone may not have the power to remove this baked-on combination. Many inexpensive wheel cleaners use an acid or petroleum solvent to dissolve this bonded contamination but these cleaners can stain alloy and anodized wheels. I use a item that works great and safe for your rims (P21S Wheel Cleaner).
3. Pre-rinse the entire vehicle. This quick rinse removes surface dirt and lowers the paint's temperature.
4. Now prepare another bucket with your favorite car wash shampoo. I also place a Grit Guard in the bottom of my wash bucket. (You'll be amazed at what you'll find in the bottom of the bucket after washing!)
5. Wash the vehicle from the top down. I use either The Bone , a Microfiber Wash Pad or a sheepskin wash mitt.
6. Rinse often during washing. After washing a section (i.e. door, fender, hood, etc.) rinse completely to prevent soap films from drying on the finish.
Detailing Secret #2 - After washing the entire vehicle, do a final rinse with free-flowing water (nozzle off the hose). This sheets most of the water off the vehicle. Trust me on this. I know it takes a minute to take the nozzle off the hose and do this final rinse but it will allow you to dry your vehicle in a fraction of time you would normally require.
7. Dry the vehicle like you washed it, from the top down. I do the roof first, then all the windows, the hood and trunk and finish with the sides. I use a leaf blowner to speed the process and then a waffle weave drying towel to finish it off.
Hope this helps you all out.
Old 06-18-2009, 08:52 PM   #4
Angelo@Autopia
You will need a polisher with foam pads with polish to remove those swirls.
Customer Complaint thread Hylton Camaro Price | Ordering | Tracking | Dealers Discussions 1299 07-23-2009 02:20 PM
If I get banned... MerF Off-topic Discussions 149 06-07-2009 09:20 PM
Could my dealer be causing my allocation frustration?? JMAN311 Camaro Price | Ordering | Tracking | Dealers Discussions 8 05-20-2009 04:04 PM
RS package on hold?? No f*u@%ing way!! arozar Camaro Price | Ordering | Tracking | Dealers Discussions 56 04-29-2009 07:43 AM
