HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 03-12-2013, 01:31 AM   #1
OhioGuy89
OhioGuy89's Avatar
Drives: 2012 LS
Jacking Points
Can anyone tell me where the jacking points are on a '67? I want to make sure I am doing it the right way. If anyone has a picture of where to jack it up, that would be even better!
OhioGuy89 is offline   Reply With Quote
Old 03-12-2013, 01:41 AM   #2
Orange Pulp Fiction
Orange Pulp Fiction's Avatar
Drives: IOM 2010 Camaro 2ss
check the dimples on the body seem below the rockers
https://www.google.com/search?q=cama...F%3B1024%3B768
Orange Pulp Fiction is offline   Reply With Quote
Old 03-12-2013, 02:11 AM   #3
ihada69L78
ihada69L78's Avatar
Drives: 2015 ZL1 M6 2015 ZL1 A6
Jack the front end under the sub-frame cross-member under the engine, or under the spring seat area of the lower control arms. Jack the back under the center of the axle housing.
ihada69L78 is offline   Reply With Quote
Old 03-13-2013, 08:18 PM   #4
GrnMchin
Not easy being Green
GrnMchin's Avatar
Drives: 67 Nova SS
Don't use the front cross member with out using some type plate steal or wood block to capture the full area of the frame or it will cause it to dish in over time. It's not supported by anything and the steal is thin.
Not my car, but I did the same thing to fix mine a very common problem and how to fixed it.
GrnMchin is offline   Reply With Quote
