Old 03-12-2013, 02:18 AM   #1
Bmatth1162
Bmatth1162's Avatar
Drives: 2011 1SS/RS LS3
Is it important to tell a tuner I have a ported TB?
I'm sick of the poor throttle response (mainly during heel/toe on the track) in the LS3 and am aware that a ported throttle body will help, which I plan to do first. If so, would it be necessary to tell my tuner (for a CAI/tune) that I have a ported TB? Does it affect how they would tune at all? Just curious, thanks
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways
Bmatth1162 is offline   Reply With Quote
Old 03-12-2013, 02:27 AM   #2
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
You should always tell your tuner all of the mods you have so he can tune your car correctly.
CHMSC is offline   Reply With Quote
Old 03-12-2013, 02:50 AM   #3
King Nothing
Under a Freightliner
Drives: Sentra, Durango and Camaro
yes tell him, a port TB let's more un-metered air into the engine
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
LQ build, 243 heads and LS6 intake
King Nothing is offline   Reply With Quote
Old 03-12-2013, 02:55 AM   #4
Liam
Tampa Bay Camaros
Liam's Avatar
Drives: 2016 Camaro 2SS, Hyper Blue
Going to a tuner is just like going to a doctor, tell him all the meds you're taking and any symptoms you are having!
Liam is offline   Reply With Quote
Old 03-12-2013, 06:19 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The more info he has to work with the better he can do his job.
Old 03-12-2013, 06:36 AM   #6
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
the throttle body itself does not have to be tuned, but it cant hurt to tell him about it. he is not going to charge more for it. and may be able to get you even more throttle response out of it with a tune.
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-12-2013, 09:50 AM   #7
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
RJT-SS is offline   Reply With Quote
Old 03-12-2013, 10:06 AM   #8
SC2150
All air the TB lets in is metered by the MAF, but he can optimize the better flow in the tune.
Old 03-12-2013, 10:08 AM   #9
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
Short answer, yes. Also, a tune will help the response. Tell the tuner that better throttle response is one of the things your looking for. My father's Trailblazer SS was really bad. Compared to it the Camaro throttle delay is almost unnoticable. He got a SLP tune done and it vertually eleminated the delay.
MikeSVX is offline   Reply With Quote
Old 03-12-2013, 10:10 AM   #10
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
Better yet................Why would you not?!?
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
10.67 @125mph Bolt-On NA
bhillakaiceberg is offline   Reply With Quote
Old 03-12-2013, 10:35 AM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
If you're sick of the throttle response you need to be looking at gears.
Build Journal
Old 03-12-2013, 10:37 AM   #12
Dznts
Anabolic Connoisseur
Dznts's Avatar
Old 03-12-2013, 12:23 PM   #13
King Nothing
the MAF adjusts for this? if this is true why would you need a tune if your adding a s/c with very low boost, air is air isn't it? i'm not tryin to be a dick at all. Honestly i'd wait to get a tune until you get more mods
M6 1 of 475
353rwhp 353rwtq
Old 03-12-2013, 01:10 PM   #14
SC2150
Not a dumb question at all, your on the right track, just terminology is off a bit.
All air entering the intake manifold is measured by the MAF (it is upstream of the throttle body) and this tells the PCM how to calculate cylinder fill rates, etc. Then the MAP also provides data and lastly the upstream O2's.
If unmetered air enters from a unvalved breather, then the PCM is going crazy and fuel trims will be all over the place as it trys to adapt and cant. But as long as the system is closed, then all air entering is metered by the the MAF. What the tuner needs to look at is the air tables to see if the increased flow of a ported TB needs to be adjust to in the coresponding tables.
So yes, a good tuner needs to know ALL the mods you have done (not appearance, just performance) to do the best job.
