Old 03-13-2013, 12:07 AM   #1
Gen5SS
Drives: 2010 SS/RS 6 Spd Manual IOM
Hesitation @ high RPM shift
Recently I had to take a short 1 week trip to a location I knew had snow and had my tuner re tune the car so I could have traction control working again like stock. I think what was initially done was open up the torque settings(I'm not savvy on the settings so I don't know exactly how this works) I now have a hesitation at high rpm while shifting from going to 6500RPM to shift to the next gear. It's like the throttle pauses for a second while shifting from 1st to 2nd and from 2nd to 3rd. It probably doesn't last that long but there is a definite break in response while shifting almost like the computer doesn't react to where my pedal is at and waits for a bit to react to the inputs its given by the accelerator pedal. Is this a tune issue or a parts issue considering I have added a Mcleod rxt and IdealG MC? I'm going to have some more work done to the car next week and I explained to the tuner whats happening with the car and he thinks its a tune issue but I just wanted some ideas if anyone has had this happen so we can figure this out faster.
2010 2SS/RS, 417 stroker, 4.0 Callies crank and rods, JRE pistons w/hellfire nitrous top rings, Kooks 1 7/8 LT, Kooks 3" Exhaust, CAI Intake and Scoop, Cam SullivanGM W/ Hardened PR, Stock Heads. Dual Springs, Mcleod RXT Clutch, Hurst LL W/ Cruise Momentary, GM 3.91 gears, Nitrous Outlet direct port 200 shot, Dedicated Fuel Cell(C16), LNC2000 and NOS Mini controller, BMR suspension w/Bushings, Pfadt Drop, Pfadt Diff Bushings, 1400hp DSS Axles, DSS driveshaft, Solid Engine Mounts, Razzi Body Kit, Speedhut Gauges,T-REX Phantom Grills (Black) 533RWHP/500RWTQ N/A, 724RWHP/816RWTQ 200 Shot
Gen5SS is offline   Reply With Quote
Old 03-13-2013, 05:57 AM   #2
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Bouncing off the rev limiter? Where is it set?
Iam Broke is offline   Reply With Quote
Old 03-13-2013, 03:14 PM   #3
Gen5SS
6800
Old 03-13-2013, 05:07 PM   #4
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
my car was doing this one time and i found that my cold air intake was not tight and letting air in at the throttle body and the mass air flow was being skipped.
fixed it and shifted fine. might look that over and see if u have the same.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 03-13-2013, 06:06 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Well if the limiter is at 6800 and you think you are shifting at 6500, you may be the victim of a lagging tach. 300 rpm goes by in the blink of an eye in 1st & 2nd. Need to log it with HPTuners or equal to see what you are really shifting at.
Old 03-13-2013, 08:44 PM   #6
Gen5SS
My tuner used EFILive to tune the car, its going back on the dynojet in a few weeks once the gears and clutch are broke in. I'll check the intake and he will test the rpm when it goes back on the dyno I'm sure. Thank you for the suggestions this is why I love Camaro5!
Old 03-13-2013, 09:26 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Could be at the limits of the stock pump. So you're not having enough supply of fuel at WOT.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 03-13-2013, 11:03 PM   #8
Gen5SS
If the fuel is the issue that will be solved shortly(I hope its not). I'm going to order the Squash system in a few days with id850's but I was going to wait to install it until I had enough money saved to buy an F1D setup.
Old 03-18-2013, 01:06 PM   #9
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
If you have 450rwhp (judging by your sig) then fuel most likely isnt the issue. The stock LS3 fuel system is still in its safe zone at that power level.
I would bet its the tune. When i leave traction control on and i bang gears (1st to 2nd, 2nd to 3rd) in colder weather (tires break traction easier) the TC/SC system kicks in quickly and momentarily and doesnt even let the TC light blink because its not losing traction long enough to trigger the dash light. But as soon as i press the TC button and shut it off when i repeat the same pull with the same gear changes, instead of a momentary lapse in throttle the car spins the tires on the gear change.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 03-18-2013, 10:04 PM   #10
Gen5SS
I took it to the tuner today for data logging. We did a few pulls with him driving and EFI Live data logging, he noticed the the same hesitation at high shift points. He is going over the data and we'll see what he comes up with. We did a run with the line lock engaged from 1st to 2nd and the hesitation was apparent there as well. I checked all the tube connections before and after the MAF sensor and everything is tight so I don't think I have an air leak to confuse the sensor anywhere. I might swap out the MAF to see if that is the gremlin. I checked to see if I had the weak MAF too and I have the good MAF. Hopefully the log shows something that we can figure it out. So frustrating He shifted at 6700 with the limiter set at 7000 with a live read from EFI and it didn't bounce off the limiter so that's not the issue.
Old 03-22-2013, 07:58 PM   #11
Gen5SS
We'll we found a rise in air flow(not sure if I'm stating this correctly) by the maf at high rpm shift. It looks like the air flow rises like a spike in airflow(the way the maf reads it) right when the hesitation happens the way the reading from the maf shows on the graph. I've disconnected the filter and intake piping to the TB and re installed it to see if that makes a difference (possible leak). I'm deleting the cats next week so when we put it up on the dyno after the install I'll report back. BTW the chatter is almost completely gone in the rxt clutch after beating on it with several high rpm launches but it seems to still have a little chatter when it gets hot from going to first to second while slipping at 1200rpm or so, hopefully that subsides.
Old 03-23-2013, 07:06 PM   #12
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
try to make sure ur gasket around ur mass air is seated good
or tb to mani gasket. if u have ever taken it off . just some thoughts. like i said before my car did the same and it was just the cold air intake boot not tight.
but had the same thing cause my car to miss under normal driving was the mass air gasket wasnt sealing up right. its weird how just a lil bit of air can mess with these cars.
Old 03-23-2013, 07:54 PM   #13
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
The only other thing I can think of is engine TRQ management kicking in to protect the car from braking something. I would shift at 6000 on the tach because of tach lag.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-23-2013, 08:48 PM   #14
Iam Broke
PHAT B33
Iam Broke's Avatar
^^^^ Good advice.
