BeckyD @ James Martin Chevy
Old 03-13-2013, 12:09 AM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Crankshaft position sensor location.....
On an L99?
I threw the code and tha car barely started. Been a miss at idle for a long time and been dying intermitently for a while. All symptoms of a bad sensor.
Anyone know where the sensor is on the L99?
Old 03-13-2013, 12:15 AM   #2
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
would it be the same as the LS3:
http://www.camaro5.com/forums/showthread.php?t=248012
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is offline   Reply With Quote
Old 03-13-2013, 12:19 AM   #3
The 2010 Sin
weaponsinc.com
The 2010 Sin's Avatar
Drives: 2014 Lifted 1500, 2013 2SS CRT
Yo PQ. I had the same code and the same crappy running engine. Have you had a weak battery lately or a dead battery? Also, there is an issue with a grounding wire on the back of one of the heads that was throwing the CPS code on my car for some reason. Dealership fixed it under warranty and loomed the cable etc. I'll find out exactly what it is that happened to me. I thought my engine was TOAST then the CPS code then VOILA! fixed.
The 2010 Sin is offline   Reply With Quote
Old 03-13-2013, 12:21 AM   #4
tandtperformance
tandtperformance's Avatar
Drives: 2010 Camaro 2011 PACE CAR 2012 ZL1
Send a message via Yahoo to tandtperformance
its above the starter on p side of engine
tandtperformance is offline   Reply With Quote
Old 03-13-2013, 01:48 AM   #5
PQ
Booooosted.
PQ's Avatar
I thought about the battery too. My sons Jeep had similar problems and it was dead battery. PLENTY of juice but still bad. (not sure how that's possible but it is)
Ya, I'd love to hear any ideas.
Thanks Tim. I'll check it out.
Originally Posted by Blue10CamaroSS View Post
I think the LS3 is on front drivers side. L99 is different.
Old 03-13-2013, 02:05 AM   #6
1sikRS
Drives: chevy
Its on the timing chain cover
1sikRS is offline   Reply With Quote
Old 03-13-2013, 02:52 AM   #7
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
I had to replace the battery out of mine this past fall. Runs great now.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 03-13-2013, 08:55 AM   #8
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
L99 and LS3, the Crank Sensor is located in the right (passenger) side of the the engine block, behind the starter. The Cam Sensor is in the front timing cover.
LSX Camaro is offline   Reply With Quote
Old 03-13-2013, 05:12 PM   #9
PQ
Booooosted.
PQ's Avatar
My sons Jeep did a similar thing. Not sure how a battery can be bad yet fully charged all the time. But it can. I'll check.
With my Maggie cooler reservoir and hoses back there it's a pain to get to. Got any idea where some pictures are? lol
Old 03-13-2013, 05:35 PM   #10
fastvee
Banned
Drives: 2011 CTS-V, 2010 SS
My 5th gen has the same symptoms.
I think I narrowed it down to the grounding but can't find the damn wire!
fastvee is offline   Reply With Quote
Old 03-13-2013, 05:41 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Oh wow!!!
Negative it's on top of the starter, all Ls cranks have the reluctor wheel at the end of the crank.
Check all your grounds. That's what it's gonna be bud. I betcha.
Old 03-15-2013, 09:04 PM   #12
PQ
Booooosted.
PQ's Avatar
Hard to get to for me. I installed the intercooler reservoir for the blower rigth back there. Hoses and shit are in the way on top of the headers and brake lines.
Originally Posted by litle88 View Post
Oh wow!!!
I hope you're right.
My tachometer went to zero the day this happened. Hasn't happened since though.
Old 05-08-2013, 11:57 PM   #13
PQ
Booooosted.
PQ's Avatar
Update................. none. lol
I never get to play with my car anymore. I still haven't found this problem.
