BORLA
Old 03-14-2013, 09:40 AM   #15
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2010 Summit White Camaro SS/RS
I did, and it's pretty simple, just make SURE to take your time, there's no need to rush it. It shouldn't take more than a few days to do it all.
gl2filmerguy is offline   Reply With Quote
Old 03-14-2013, 09:45 AM   #16
2012REDSS
Drives: 2012 Camaro SS
I dont know about the ECS bracket system compared to the Vortech but Id imagine they are very similiar. This is the area that gave me the most trouble. There were alot of different size bolts and spacers that have to be assembled perfectly for the belts to track true. Take your time and it will be no problem. I didnt have a right angle drill so I just removed my radiator to pin the crank and it was easy. Also use a balancer install tool and you can put the balancer in the oven at 200 degrees for 20 min and it will slide on the crank pretty easy. Good luck and post pics.
2012REDSS is offline   Reply With Quote
Old 03-14-2013, 11:27 AM   #17
East Coast Supercharging
East Coast Supercharging's Avatar
Drives: 8 second C5 Drag Car, C6 Road racer
If you have any questions we are here to help also!
Many people tackle this themselves without a problem, hopefully you do too. If you would like a start up tune file send me your ECM when you start the project and I'll turn it around the same day received.
It still needs to be checked, but it will be very close if not spot on and you can check the cars operation prior to dynoing.
Thanks!
East Coast Supercharging is offline   Reply With Quote
Old 03-14-2013, 02:10 PM   #18
grocerygetter
instigator
grocerygetter's Avatar
yup...get it tuned by them or someone local. I was going to bring that up. pinning the crank is the hardest part IMO.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 03-14-2013, 03:24 PM   #19
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/2012 SS
Im either taking it to Lethal Performance or Henderson Performance, called both of them for a quate on a tune but didnt get a awnser from either one. Left a msg so hopefully ill hear something from them..
Thank alot everyone for the tips and encouragment!!
2012InfernoSS is offline   Reply With Quote
Old 03-14-2013, 04:02 PM   #20
grocerygetter
instigator
lethal would be my choice just for the volume of ECS they do. You know if you need something they will have it or can get it asap.
-John S.
Thanks to:
Tony@ dv8motoring
Old 03-15-2013, 08:53 AM   #21
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Pinning the crank is easy on the ECS kit. Don't have to remove the balancer. Also don't have to remove front bumper cover. Hardest part is figuring out what spacers go where. Study the install pics in the instructions as you do the install. ECS can explain what spacers go where. FSP helped me a lot, I bought from them and installed myself.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 03-15-2013, 04:08 PM   #22
2012InfernoSS
Ya I looked at the spacers when the kit first came in and said to myself, this is going to be fun..
Maybe someone can do some measurements on those to make my life easier lol
Old 03-20-2013, 10:11 PM   #23
2012InfernoSS
Anyone remember were this bolt went?
Also on the hobbs there are 2 screws, one says nc the other has no.. what one is for the bap black wire?
Old 03-22-2013, 12:09 AM   #24
2012InfernoSS
Bump
Old 03-22-2013, 12:36 AM   #25
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Lethal Performance in San Antonio just recently moved to a new location so that may be why you couldn't reach them. They are the shop I would go with in that area.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 03-22-2013, 03:44 PM   #26
AintQik
Drives: 67 Pro-Tourer, 12 SS
Doesn't matter on the hoobs. One side goes to bap one to ground. That bolt does not look familiar. What length?
AintQik is offline   Reply With Quote
Old 03-23-2013, 09:52 AM   #27
2012InfernoSS
Ya im going to lethal talked to some of the guys last night
Old 03-23-2013, 10:13 AM   #28
2012InfernoSS
