JUICEDMOTORSPORTS
Old 04-08-2013, 09:08 PM   #57
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
Nice 600-700 hp wow!!! Thats pretty crazy for the v6.I never imagined our motors can handle that much.My goal is to get in the 12's but id be happy if i can run low 13's all day and still have good reliability.
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
Vader2011v6 is offline   Reply With Quote
Old 04-08-2013, 09:24 PM   #58
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
You should be able to run that if you can get traction.
Old 04-08-2013, 10:09 PM   #59
KeepItShut
KeepItShut's Avatar
Drives: 2011 CGM 2LT/RS
Originally Posted by SC2150 View Post
The lift pump has no effect at these levels of boost...it is the HPDI pump that runs off the cam lobe on the rear of the drivers cylinder head.
Lots of options for more fuel....thats how some of us are pushing 600-700 plus HP on these.
Whose LLT has those numbers?
KeepItShut is offline   Reply With Quote
Old 04-08-2013, 10:15 PM   #60
Vader2011v6
I sure hope so. That's what I'm hoping. The good thing is that I'm not a horrible driver. Not the best though. I ran 14.56 @ 95mph with 20 inch wheels that are a little heavier then stock SS wheels an a K and N short ram.
Old 04-08-2013, 10:42 PM   #61
lscamaro
lscamaro's Avatar
Thats a pretty good time if that's all you had on the car. You'll probably have to learn how to launch it again but once you get it down, you should be able to run at least consistent mid to low 13s. If you get some serious rubber, I think you can get into the 12s, especially with your mods.
Old 04-08-2013, 11:06 PM   #62
KMPrenger
KMPrenger's Avatar
With your power, if you can get a decent launch you car is definitely capable of 12s. You can be happy with low 13s, but its capable of more. There have already been two IPF cars hit 12s...one of them on stock tires with stock headers. The other car I can't remember if it had stock tires or not.
IPF also took an LS (with the heavy 18" heritage blank rims and all season tires) to a 13 flat.
So again if you get a good launch you should be able to see 12s. Otherwise if you spin badly at the launch it will kill your time.
No LLT on this site has those numbers right now. Gretchen got to around 600 crank HP with his LLT, but the tune and fuel was not stable. But now he is running a 2012 V6 with the LFX hitting at about 700 HP.
Old 04-08-2013, 11:32 PM   #63
Vader2011v6
Yeah I saw that. Is there any manual supercharged cars that are running those times?i mostly see autos.
Old 04-08-2013, 11:51 PM   #64
lscamaro
lscamaro's Avatar
Oh wait, is your car a manual or an auto?
Old 04-08-2013, 11:52 PM   #65
Vader2011v6
Manual
Old 04-08-2013, 11:54 PM   #66
lscamaro
lscamaro's Avatar
Oh well you're definitely going to have to relearn running this thing. How does the clutch feel with the boost? I know a bunch of people, are looking at getting upgraded clutches because of the new found power.
Old 04-09-2013, 12:08 AM   #67
Vader2011v6
It feels pretty good.I don't intend to put drag radials as for the car is my daily driver.i figure that when the clutch goes out and starts slipping I will look into a new clutch. Seems like there's only a few out at this moment.As for learning to drive the car oh definitely. Ive have only launched it once with the supercharger. I launched it at 2800 rpms and feathered the clutch. I probly will go to a test and tune so I can get more runs.theres a race track about 15 mins away from me.
Old 04-09-2013, 12:11 AM   #68
lscamaro
lscamaro's Avatar
If you don't want to put drag radials on, you could look into some better rubber or some suspension goodies to avoid wheel hop and keep things planted making it easier for you to control traction.
It should be fun getting that thing to a drag strip to see what it can do!
Old 04-09-2013, 11:15 AM   #69
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Since the power doesn't really hit until the upper half of the RPM range on the IPF set-up, I rarely have traction problems with my M6 car on the stock all-season BFG's that came with my LS. I have not run mine down a 1/4 mile yet, though, and with the closing of the only accessible track in the Phoenix area, it'll probably be a while, if ever, until I do. We have to trek to Tuscon, almost two hours away at this point to get any runs in.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 04-09-2013, 11:37 AM   #70
lscamaro
lscamaro's Avatar
That sucks :(
That's interesting that you say traction isn't an issue. I've been interested in seeing since as you said, the power doesn't really kick in until the upper rpms
