Lethal Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > 2016 Camaro: 6th Gen Camaro forum, news, rumors, discussions
Old 03-19-2013, 03:54 PM   #51
revychevy
revychevy's Avatar
Drives: 2010 2SS RS LS3
Originally Posted by CAP'N B View Post
(QUOTE) You really have no clue what amazing things gm is accomplishing with the pushrod v8 do you? (A) Yes I do, I was born in 1961, I think I came before the V8.
(QUOTE) With overhead cam engine you have to rev them out to get any performance at all. (A)This makes absolutely no sense whatsoever, it's the same thing as a cam in block. The cam HAS to turn in conjunction with the crankshaft. The placement and the amount of cams is different, the drive is the same. Just a bit more expensive.
(Quote)Go buy a BMW or get educated... (A) Not only foreign cars have OHC I'm, sure there are a few floating around GM, FORD, DODGE already. I need to get educated???? 1 of you is 24 and the other is 26, I was taking apart gas and diesel engines when you were still a lump in your dad's pants.
Ok maybe not a dinosaur, I was born before the V8 so I may be considered a dinosaur LOL.
The pushrod is a weak link, the lifters are a weak link and the valve train instability probably cause more total engine failures than probably any other failure. The OHC engine lends itself to better valve train stability and higher performance, higher revving engines. OHC design is a bit more expensive. But you spend money anyway to make your engines more powerful.
What about the possibility of doing away with spark plugs. Nothing at all was commented on that.
People feel the same about carburetors and fuel injection. Some embrace different technology some don't.
Cool story bro, but Cadillac had a production V8 in 1914. They weren't even the first. Rolls Royce and Renault did it before in small quantities. You are not older than the V8 engine.
2SS RS bone stock for now...
revychevy is offline   Reply With Quote
Old 03-19-2013, 11:44 PM   #52
WHAMMO
WHAMMO's Avatar
Drives: LS2 Fbody
Originally Posted by mr02Z/28 View Post
I would be happy with a H.O. 5.3L in the range of 390-410HP if the 6th Gen weighed in at around 3300-3400lbs........
I would not be happy with that, because the Ford Coyote pumps out 420hp with 5.0liter...
4th Gen SS/LS2 SB/LS3 heads/N20
WHAMMO is offline   Reply With Quote
Old 03-20-2013, 12:47 AM   #53
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: ZL1 #206 (SOLD) 6th Gen?
Out of all that I got owners of the Corvette are generally 40 years old or higher. Guess ill be getting a C8 when my time comes.
FINALLYSATISFIED is offline   Reply With Quote
Old 03-20-2013, 04:04 AM   #54
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Yes but that's the only v8 they offer as where this would be the base v8 option sorta like the 305 of the 3rd gens and the 6.2 would be the 350 and make a lot more power then the 5.0.(atleast for now) I think a 1ss with a 5.3 and more mpg friendly gears at a lower cost would help sales and then allow the 2ss to be offered with the big boy 6.2 at a higher cost and better gearing.
He is like the jedi night of gayness. If hitler and henry ford had a special needs child together it would probably be the pill.
NASTY99Z28 is offline   Reply With Quote
Old 03-20-2013, 09:34 AM   #55
LOWDOWN
Downright Upright
LOWDOWN's Avatar
Drives: Daily
Something to keep in mind when comparing Coyotes to other critters is the physical size of Ford's OHC V8s...much larger in width and height than the SBC. Weighs more, too.
So now you run into packaging issues. More boiler room required. Cowl height and frontal area issues. And don't forget a Lincoln 4-dr is supposed to share the next-Gen Stang chassis, too. If so, Lincoln will have input as to body-chassis structure and specs, just as Cadillac has with the Alpha derivatives.
There's an opportunity for GM to create a Gen-6 Camaro that, for once in a long-long time, is the same size or even smaller/lighter than the next-Gen Stang...and the physical size of the SBC plays a part in that overall physicality.
LOWDOWN is offline   Reply With Quote
Old 03-20-2013, 10:10 AM   #56
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
I think a 1ss with a 5.3 and more mpg friendly gears at a lower cost would help sales and then allow the 2ss to be offered with the big boy 6.2 at a higher cost and better gearing.[/QUOTE]
yep, this has been part of my point..if they can get those HP ratings out of a smaller displaced engine, they can get better MPG's with it and in turn, keep the super high, even supercharged beasts in the line-up. But Honestly with less rotating mass, the 5.3L will rev quicker, will have comparable power and the 6th gen will weigh less thus making an awesome track car..with good MPG's LOL
Mikes SS is offline   Reply With Quote
Old 03-20-2013, 12:26 PM   #57
fielderLS3
fielderLS3's Avatar
Drives: 02 Alero, 2011 Mustang 5.0
We both know that's not the way it will go down. It's not like a 5.3L displacement engine will be cheaper to produce than the 6.2. If both are offered, a 5.3L V8 won't cost less than the current 1SS, it will be the same. You want a 6.2L, you'll have to pay thousands more in the first year of the 6th-gen than in the last year of the 5th gen if they go the 2 different displacements route.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 03-20-2013, 07:49 PM   #58
Captain Awesome
Drives: 2010 Camaro 2SS/RS
How many RPMs does your Avatar guy's weekend pushrod car turn all afternoon long at wide open throttle?
Captain Awesome is offline   Reply With Quote
Old 03-20-2013, 09:02 PM   #59
OldScoolCamaro
ZL1 pilot
OldScoolCamaro's Avatar
Drives: 2012 ZL1, 1973 Z-28
....seriously, what are you saying? Look, take a stand, be factual, hold an opinion, but please stop seemingly taking the position of an antagonist with the overt intent to elicit controversial responses for ones own enjoyment. Sorry, ....
OldScoolCamaro is online now   Reply With Quote
Old 03-21-2013, 06:51 AM   #60
Agent orange
socal ht5
Agent orange's Avatar
Drives: 2010 Camaro ss
Probably its gonna be the same format. The ss will be the same engine as the base stingray engine.
Agent orange is offline   Reply With Quote
Old 03-22-2013, 12:57 AM   #61
WHAMMO
WHAMMO's Avatar
Drives: LS2 Fbody
The Coyote weights 430 and the LS3 418lbs. I'm wondering what is the weight of the LT1..
I know the LS3 is smaller in size, but Ford did pretty well because the 5.0 didnt gain any size over the 4.6, if I'm not mistaken. Maybe its even more compact than the 4.6l.
Old 03-22-2013, 06:21 AM   #62
NASTY99Z28
Never said the 5.3 would be cheaper to build. They could offer it at a lower power level day around 385hp since its going to be in a lighter chassis and then they could charge extra for the 6.2. It will probably never happen but it would be cool to have a budget v8 option.
Old 03-22-2013, 11:52 PM   #63
fielderLS3
fielderLS3's Avatar
Exactly.
Old 03-23-2013, 03:41 AM   #64
NASTY99Z28
Exactly.
After thinking about it I take back what I said about the 5.3 not being cheaper to produce. Since it's used more across the GM line up it should cost less overall for GM to build it compared to the 6.2 since its a "premium" engine and they make less of them. Yes I know a lot of the parts are the same but there enough parts that aren't that would allow for cheaper build cost based on the volume of each engine size. Once again I doubt it would happen but I would like to see two different v8 options simply because I think its cool and it allows each buyer to have a choice which is something we haven't had since 92.
Old 03-23-2013, 10:00 AM   #65
revychevy
revychevy's Avatar
They are putting a 6.2 liter V8 in the New SS sedan, they put 6.2 liters in the Stingray, why would they put a smaller displacement engine in the best selling pony car in the land?
So the Camaro SS can get beat by the GT? Again? Put that DI 6.2 in that baby and there is your mpg savings AND your grunt. How do you even argue that the 5.3 liter is better than 6.2 if they are both DI with cylinder deactivation?
Old 03-23-2013, 10:29 AM   #66
revychevy
revychevy's Avatar
Although I must admit AFM seems like it sucks from all accounts on camaro5 and every other Camaro site I have seen...
Old 03-24-2013, 01:59 AM   #67
fielderLS3
fielderLS3's Avatar
The logic could work both ways. Any savings based on the volume of the 5.3L displacement could be offset by differences between the truck engines and car engines. The 5.3L is the volume truck engine, but the volume advantage of the 5.3L displacement may be offset by the volume disadvantage of having a unique version of the 5.3L just for the Camaro. It depends on exactly what is interchangeable.
Ultimately, whatever cost differences there may be between the various displacements and applications of the small blocks is probably fairly small, certainly not anywhere near enough to affect price to the point that another trim can be separated out. So even if a 5.3L SS was offered (and it probably won't be), it will likely be priced where the current 1SS is, not below it. Sure, the 6.2L comes with a price premium in the trucks, but not because it costs GM that much more. It's mostly just marketing (attaching the larger engine to premium trims). The standard models pay for themselves and get people in the door, but the options are where the real money is made.
Old 03-24-2013, 02:42 AM   #68
NASTY99Z28
Never said a 5.3 is better then a 6.2 just liked the idea of multiple v8's. A 5.3 is a great engine and I'm sure it's going to be even better now with di so don't act like it can't be a strong setup when paired up with a lighter 6th gen camaro. A lot of people want a v8 but don't need or want the baddest setup which is why every v8 camaro sold isn't a zl1.
Old 03-24-2013, 02:45 AM   #69
NASTY99Z28
Agreed but a man can still dream......
Old 03-25-2013, 10:05 AM   #70
Mikes SS
Mikes SS's Avatar
Its also the point that that the 5.3L DI will get better gas milieage than the 6.2L...if we all want to keep our V8's in the future, I am all about having an option for a smaller standard V8 to help the company with CAFE ratings, and yes as we say we will pay to play, if you want the bigger engine you will pay for it.
Old 03-25-2013, 12:28 PM   #71
fielderLS3
fielderLS3's Avatar
Why are so many people here so accepting of the notion of something standard in the 5th gen model becoming a premium option that will cost considerably more in the 6th gen?
Old 03-25-2013, 12:37 PM   #72
Bhobbs
Bhobbs's Avatar
Drives: 1998 Camaro Z28, 1970 Chevelle
Because people are rolling over and letting the government dictate what we can and cannot have.
Bhobbs is offline   Reply With Quote
Old 03-25-2013, 12:47 PM   #73
Kevlar382
Kevlar382's Avatar
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv
Originally Posted by meissen View Post
I'm really surprised at the news about a "base" Corvette... My understanding was that they were calling the C7 the Stingray because they wanted everyone to feel like they were getting that "upgraded" model. If they wanted a base then they should have had just a Corvette, and then the Corvette Stingray as an upgraded model. Doesn't make sense and contradicts what they were saying when the C7 was unveiled.
The way I understand it the 5.3 Vette is called the Corvette Coupe, not a Stingray. Different hood, front fenders, and a none removable top. GM is the one that said it was going to use the "truck 5.3". This is how the C5 ZO6 started out, as a less expensive Vette with the truck motor, but the last minute put the 345hp motor in it. Later they put 405hp in it and called the ZO6.
Kevlar382 is offline   Reply With Quote
Old 03-25-2013, 12:55 PM   #74
fielderLS3
fielderLS3's Avatar
When did the C5 Z06 ever have an LS1? I recall it being launched with the LS6 right out of the box, 385hp the first year, and then 405hp after than.
Old 03-25-2013, 01:42 PM   #75
Bhobbs
Bhobbs's Avatar
The Z06 always had the LS6. The LS1 was in the base Corvette.
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
