Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V8
Old 03-15-2013, 11:05 PM   #1
forklord's Avatar
Drives: 2010 2SS
Smaller pulley...what belt size?
going from 3.5" to 3.0" pulley. will i need a tighter belt? edelbrock said stock belt size for eforce is 105.5" so would a 104.5" gatorback be too small? its the next size down...and im assuming the stock pulley is im questioning if its 3.75 for some reason lol...thanks
forklord is offline   Reply With Quote
Old 03-15-2013, 11:46 PM   #2
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Not sure about Camaro, but on my vette I have gone down 2 pulley sizes using the same belt. I would try the belt before buying a shorter one.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 03-16-2013, 11:51 AM   #3
Drives: SS/RS
Send a message via AIM to epstein
the LS3 ...... comes with 3.75
The l99 ....comes with 3.5
epstein is offline   Reply With Quote
Old 03-16-2013, 11:56 AM   #4
Drives: 2011 Camaro SS RS
I just put the 3" pulley on mine. I know they changed the belt and if you PM me I will tell you the belt size. My car is in storage right now and I have the paper work in it. I can have it tonight for you.. I know they had to try a couple of belts until they got the right one.
Supermaro585HP is offline   Reply With Quote
Old 03-17-2013, 03:09 PM   #5
SilverIceman's Avatar
Drives: Camaro SS SIM
According to Edelbrock,
LS3 comes with 3.5" pulley
L99 kit comes with 3.875" pulley
Would be curious where your boost level is with the 3.0" pulley.
SilverIceman is offline   Reply With Quote
Old 03-17-2013, 04:38 PM   #6
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
I would think a good aftermarket belt tensioner would take up that slack but I may be wrong.
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
belt, camaro, eforce, ls3, pulley
