SDPC
Old 03-17-2013, 01:25 PM   #1
camaro2lt
camaro2lt's Avatar
Talking DIY-ZL1 bumper cold air intake ducting
Hey guys this is one of the cheapest mods i did and might even gain some power. I wanted to add some cooler air to my bbk open air filter intake,soo the other day i went to my lowes and bought some Flexible aluminum air condition ducting for 10.95 and some 24in zipties.The air comes throug the drivers side corner of the zl1 lower grill (this is where the brake cooling ducting would be on a actuall zl1) And bent the pipe to let the air out right on the open filter. Here are some pics if anyone has any questions post them up!
-richie
Old 05-19-2013, 07:27 PM   #2
BudMC77
BudMC77's Avatar
Drives: 2011 Camaro 1LT
Clever..any chance you have any other pictures of it, like where you zip tied it down or anything?
BudMC77 is offline   Reply With Quote
Old 05-19-2013, 07:46 PM   #3
camaro2lt
camaro2lt's Avatar
i will get some pics tommorow
One place i ziped tied it was too the wheel liner i drilled to small holes in the ducting and in the wheel liner then ran a zip tie
i also zip tied it to the radiator plastic wind deflector
i want to paint it black soo it blends in but need to take the bumper off
Old 05-20-2013, 06:24 AM   #4
hworth18
Jus' Cruzin
hworth18's Avatar
Drives: 2011 Camaro 2LT/RS Convertible
You might try some of that landscaping drain flex pipe, it's already black and would blend in better. Good idea though, thanks for posting!!!
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark
hworth18 is offline   Reply With Quote
Old 05-21-2013, 10:18 AM   #5
BudMC77
BudMC77's Avatar
Just cut the zip ties and take it out, paint, and then re-zip tie it.
Old 07-01-2013, 02:56 PM   #6
usranger80
usranger80's Avatar
Drives: 2011 1LT "Bumblebee"
I did this too to replace my ADM scoop since it won't fit any more, 4 dollars for a 24" elbow piece of black drainage pipe and I have a scoop again that feeds right into my CAI
usranger80 is offline   Reply With Quote
Old 10-26-2013, 04:23 PM   #7
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Great idea, thanks!
Inuyashas_Brother is offline   Reply With Quote
Old 10-26-2013, 04:34 PM   #8
Inuyashas_Brother
How much length is needed? Do you think this would work:
InvisaFlow DownSpout Connector
http://www.homedepot.com/p/InvisaFlo...N#.UmuZ2lBjuSo
Old 10-28-2013, 10:28 AM   #9
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
The black pipe would work better than the metal stuff too, wouldnt absorb heat as much
