Emblempros
Old 03-19-2013, 01:54 PM   #15
islander033
SLOBRA1
islander033's Avatar
Drives: GT500/Cruze/DMax/Cobra
Originally Posted by sammyv View Post
... Looking forward to dyno no's and 1/4 mi times!
X2!^^^
2010 GT500 Best ET=10.10 - Best Trap=143.59mph
2003 Turbo Cobra Best ET=8.32 - Best Trap=164.51mph
islander033 is offline   Reply With Quote
Old 03-19-2013, 04:38 PM   #16
The Baron
The Baron's Avatar
Drives: 2013 zl1
Lol light bolt on gt500 huh? Lol with the converter UNLOCKED I'm shooting for upper 600s.. I say unlocked because we are doing the street tuning right now and I can already tell the converter clutch can't hold. Looking for low 700s after its fixed.. this combo is not new and makes 770s in 6 speed cars.. I'm going to Bradenton and running the car then coming home and taking the converter out and sending it in..
Here is a good idle vid
http://m.youtube.com/#/watch?list=UU...wQ%26index%3D1
I'm running meth and so far we are to about 15#s at PART throttle runs. With the meth the fuel pump will be fine.
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
Old 03-19-2013, 04:58 PM   #17
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
That sounds really healthy!
ZL1-V is offline   Reply With Quote
Old 03-19-2013, 10:25 PM   #18
The Baron
The Baron's Avatar
Drives: 2013 zl1
still tuning.. the stock pump is DONE.. the meth is keeping it happy but a fuel pump is going to need to get figured out after bradenton..
Old 03-20-2013, 04:19 AM   #19
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Don't get me wrong I'm not trying to slam u or your car I love zl1's and would take one over a gt500 in a heart beat. Now at the same time the gt500 can easily hit 700whp and in a lighter car although you have a stalled auto which should help make up for that and I wish u the best of luck and will continue to follow your thread. Once again I'm sorry if my last post came off wrong.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 03-20-2013, 02:12 PM   #20
newmoon
newmoon's Avatar
Drives: 2012 5.0 Mustang, Brembo Track Pack
700 rwhp in an automatic with a converter has got to be a very low 10 sec, to high 9-sec ride. Can't wait to see your slips, best of luck to you.
Presently Car-Less
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 03-20-2013, 09:38 PM   #21
The Baron
The Baron's Avatar
Drives: 2013 zl1
Car chews right through the converter.. back to tje drawing board. Rigjt now I can honestly say I was way wrong about the stock fuel pump as well.
Old 03-20-2013, 09:44 PM   #22
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Do you have anything against a BAP? That should meet your fuel requirements.
Trackman is offline   Reply With Quote
Old 03-20-2013, 09:46 PM   #23
DrkPhx
DrkPhx's Avatar
What brand converter are you running? Sounds like you're blowing through the converter. I would contact Chris at Circle D for a mutli disc converter or see what he recommends. I ran his 5C in my TA with a stroker motor and loved it.
Old 03-21-2013, 12:46 AM   #24
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
I have a yank multi disc and im pretty happy with it
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 03-21-2013, 06:33 AM   #25
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28, '17 ZL1 A10
3600 was a bit loose or the converter clutches not rated for the hp/tq? I bet the stock converter would not have been too bad.
'17 ZL1 A10 Mosaic Black PDR/Nav
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-21-2013, 08:06 AM   #26
JWR046
JWR046's Avatar
Drives: 2012 ZL1 #1786
Holy crap that sounds bad azz. Curious once everything is fully setup what you will set for power. You should be able to set some good numbers in the 1/4 as long as you can hook that bad boy up. So I assume no factory warrantee. LOL
JWR046 is offline   Reply With Quote
Old 03-21-2013, 10:14 AM   #27
The Baron
The Baron's Avatar
Drives: 2013 zl1
I'm going to get it fixed in the next week or two.. this sucks because I would have been loading it to put ona trailer today to head for bradenton.. I might do a boost a pump at first but that is notva ultimate solution. The car is moving enough air according to the logs to be making in the 850+hp range (crankshaft) so a real fuel system and maybe a forged shortblock are in its future. . My goal is to run as fast as I can with the stock blower so I'm going to do what I need to do.. for right now new converter and a bap will get it moving and to the track..
As of right now the car is making 16-17 pounds of boost with every bolt on and the meth is keeping the inlet temps in the blower hat 10degree above ambient. . I CANT say enough about how Good Chad at C.B.I has been about squeezing the power out of this thing. The custom grind I put in here has went in several of his other centri blower cars and made big power but I was skeptical about a cam with such mild specs for this build. The car idles at 750 rpm and drives like a champ (minus the stall not holding under wot) I have the blower at max drivable speed at 6500 and am commanding the car to shift at 62-6300..
Old 04-07-2013, 08:24 PM   #28
Trackman
Trackman's Avatar
