Old 03-17-2013, 09:32 PM   #1
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Question about how the Trans is commanded to shift
Problem I have is my trans don't want to shift from 1-2 when commanded to. Rest of the shifts are fine. In my tune for WOT 1-2 is set at 28mph and rpm 6300. But it's not shifting till around 6900/7000. So it likes to hit the rev limiter. Is there something else in the tune that tells it when to shift? The other shifts 2-3,3-4 seem to be shifting on the rpm but not 1-2.
I'm guessing it's hitting the rev limiter because it's pulling the throttle position to 40%, But I had the rev limiter set to 7200.
Nitroman28 is offline   Reply With Quote
Old 03-18-2013, 05:04 AM   #2
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Who did your tune?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 03-18-2013, 08:13 AM   #3
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
I have to command 17 mph in first gear. It doeant care about commanded rpm, on wot mph commanded. I'd drop it down another 2-3 mph and try it. Because I'm picky I also like to make sure the wot area of all the shift tables is set the same as the wot mph table.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 03-18-2013, 08:14 AM   #4
Rhino79
Rhino79's Avatar
There is also a rev limit acceleration modifier that will " soft limit" before the 7200 hard limit depending on rate of acceleration. You can 0 that table out.
Old 03-18-2013, 09:36 AM   #5
Nitroman28
Nitroman28's Avatar
Thanks Ryan, I'll give that a try, Going to have to wait for this rain to go away before I can try it..
Old 03-18-2013, 09:53 AM   #6
Rhino79
Rhino79's Avatar
Lol. I know, I got stuff I need to do today and the rain is slowing me down.
Old 03-18-2013, 10:34 AM   #7
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Sure that is not a ECM Torque limiter that you are hitting? All of these programs are now based off of predicted torque and if the scaling is not correct and/or you are above the predicted torque range it will pull throttle out. I see you have HPTuners, you can ask me for my config file if you want just shoot me a PM with your email.. You'll have to log at least these to find out whats going on:
ETC Source
ETC Commanded Pedal
Accelerator Pedal Pos
Fuel TQ Mngt Type
Spark TQ Mngt Type
Engine Torque
ETC Position
You'll see the ETC Source go from Pedal to Torque and it will cut back the Torque.
- Matt
Matt @ FSP is offline   Reply With Quote
Old 03-18-2013, 11:08 AM   #8
Nitroman28
Nitroman28's Avatar
ETC Source
ETC Commanded Pedal
Fuel TQ Mngt Type
Spark TQ Mngt Type
Engine Torque
ETC Position
- Matt
I've still got your email, I'll send one over..
Old 03-18-2013, 11:39 AM   #9
Matt @ FSP
Matt @ FSP's Avatar
Shot you back a mail..
Old 03-18-2013, 03:20 PM   #10
Rhino79
Rhino79's Avatar
For what its worth, I have to lead my 1-2 shift by 17 mph for it to execute at the rpm I want to shift at. Sure I have a shorter 1st gear, but mine tops 1st at 35 mph @ 6900 rpm.
Old 03-18-2013, 10:13 PM   #11
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Your not a low horsepower caramo, and the computer doesnt have a chance to react to how fast your hitting your 1-2 shift point exchange, plus your losing traction at that shift point which is making it spool faster and blowing passed your shift point.
Lowing your shift point on the 1-2 shift.
Tampa Tuning is offline   Reply With Quote
Old 03-18-2013, 10:37 PM   #12
Nitroman28
Nitroman28's Avatar
Yea I'm going to try and lower the mph and drop the RPM down about 600 and see what happens, Hard to test it on the road, will have to wait till I get back to the track.
