Gen5DIY
Old 07-19-2013, 08:07 AM   #15
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
So, has anyone heard anything new? I can't wait to see what we can adapt for use on our engines.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 11-09-2013, 06:35 PM   #16
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
I did a little reading on some dyno testing on the LF3. It seems to confirm exactly what I figured GM was doing with this engine, and what it is capable of:
http://www.edmunds.com/car-reviews/t...no-tested.html
In dissecting the ECU programming, there are specific torque target tables, and the ECU is empowered to do many things to get to those levels, including throttle reduction, boost reduction and timing reduction. We saw the throttle drop close to 50% right after spoolup in some cases which is where the little drop off in torque comes from. But later runs showed less torque here as the ECU learned and was more predictive. This would be less prevalent on the road because the load on the dyno is somewhat higher especially at low rpms, causing the boost response to be more aggressive. The ECU is arguably the most complex spark ignition ECU that GM has ever used. Not only do we have target torque tables, but the torque models includes things like turbocharger compressor efficiency, predicted turbocharger turbine speeds, and many other variables. I can't wait to start tuning them as based upon the way ECU is limiting the output in stock form, this engine will easily pump out 500+ lbs-ft of torque and 460-480 hp with minimal mods/tuning and should come close to matching the old CTS-V acceleration wise when doing so (I own a 2010 CTS-V 6MT myself). And as JK said, what does this tell us about the next CTS-V? Can't wait.
I am pretty certain that IPF has their hands on one of these bad boys. Hopefully we will see their results soon.
Old 11-10-2013, 05:45 AM   #17
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
This was a head 2 head featuring the LF3.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 12-30-2013, 08:20 PM   #18
KMPrenger
KMPrenger's Avatar
I've been searching for quite awhile to find tuning results for this engine.
I finally found something from KPE (I believe also partnered with IPF or something along those lines) and the results are pretty impressive if you ask me.
The graph below is from the XTS VSport, not the CTS-VSport and I think this is an AWD model. I'm looking forward to seeing results from the CTS RWD cars.
Green is stock. Blue is a stage 1 tune, and red is the stage 2 tune.
From: http://www.cadillacforums.com/forums...uning-kpe.html
Old 12-31-2013, 07:49 AM   #19
GretchenGotGrowl
Didn't Arno say they always correct for drivetrain loss? If so, then those numbers seem low. If they are really at the wheels then those are some nice numbers for a AWD vehicle. It would be nice to see the boost and AFR plotted as well.
Old 12-31-2013, 08:11 AM   #20
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
dyno
I agree. This might be fly wheel numbers.
Old 12-31-2013, 10:35 AM   #21
TexasCamaro5
Bayou City Muscle Cars
Drives: 2010 Camaro 2LT/RS
Nice to see a force inducted production v6 from an american auto manufacturer, although I think we all want to see 500+hp or even 600hp from a v6 while maintaining efficiency while ensuring the engine's integrity.
I take it the LF3 is an iteration on the LFX which is an iteration on the LLT?
TexasCamaro5 is offline   Reply With Quote
Old 12-31-2013, 10:39 AM   #22
GretchenGotGrowl
It is in the same class as those two, but has lower compression ratio, different crank, pistons, rods and cam shafts. The HPFP has higher capacity as well. There are a few other differences but I can't remember off the top of my head. So, it is about as different from the LFX as the LSA is from the LS3.
Old 12-31-2013, 10:55 AM   #23
TexasCamaro5
Ok that makes sense.
Old 12-31-2013, 05:28 PM   #24
KMPrenger
KMPrenger's Avatar
Yes and No.
Seems like the graphs he shows from his tests in foreign countries are always crank power.
This was from a shop in Scottsdale Arizona and the power numbers are listed as "AWHP" and "AWTQ" as in from an all wheel drive version of the XTS
See above. I highly doubt this is crank power....which means there is some very impressive power there.
Old 12-31-2013, 07:23 PM   #25
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
Well stock is advertised as, what, 420/430 crank power? And he has 350/326 as the stock numbers, which would be around correct for AWHP...
Mods: (VMAX Ported Throttle Body, old), K&N CAI, 1LE Strut Tower Brace, Solo High Flow Cats, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, Custom 3" Magnaflow Exhaust, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch
DSX_Camaro is offline   Reply With Quote
Old 12-31-2013, 08:02 PM   #26
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
I just want the pistons and the rods lol.
Sent from my Samsung Galaxy Note 3
Can't_C_Me is offline   Reply With Quote
Old 01-02-2014, 08:31 AM   #27
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
My bad I was looking at the graph on the top of the left hand corner that says Eng Power/ Eng Torque.
Old 01-03-2014, 04:40 PM   #28
HP Turbine
Boosted
HP Turbine's Avatar
+1
