Old 03-18-2013, 02:54 PM   #1
000montoya
000montoya's Avatar
Drives: 2014 RedRock 1LE
need help picking tires for my tsw rims
i just bought some TSW Nurburgring 20" Rims they are 20x9 in the front and 20x10 in the back.. i needed help finding out if these tires would fit it
http://www.tirerack.com/tires/tires....S&autoModClar=
000montoya is offline   Reply With Quote
Old 03-18-2013, 04:10 PM   #2
Denis
Denis's Avatar
Drives: 2010 SS
They'll fit the front but not the back. You need to go wider in the back, I'd say at least a 295's back there due to the 10" rear wheel.
Just curious, what finish did you go with on the wheels?
Old 03-18-2013, 04:49 PM   #3
000montoya
000montoya's Avatar
oh ok thanks for the info.
I bought them used from someone on the forum and he said they're matte black but they look grey like the picture in your signature
Old 03-18-2013, 05:16 PM   #4
Denis
Denis's Avatar
Drives: 2010 SS
Not to mention those tires are labeled at truck tires.....
Old 03-18-2013, 05:33 PM   #5
nele22
nele22's Avatar
Drives: 2012 SS
I have 275/315 set up on my TSW's. Same width as yours.
nele22 is offline   Reply With Quote
Old 03-18-2013, 05:36 PM   #6
Denis
Denis's Avatar
Drives: 2010 SS
That's what I'm running but I'm running INVO's. I'm told that the Invo's run small soooo a 315 INVO is really equal to a 295 on comparable tires. There's a thread on here somewhere about it.
Old 03-19-2013, 06:18 PM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Originally Posted by Denis View Post
That's what I'm running but I'm running INVO's. I'm told that the Invo's run small soooo a 315 INVO is really equal to a 395 on comparable tires. There's a thread on here somewhere about it.
Yep, guys have got to be careful with the Nurburgrings.
I've seen a 305 P-Zero on a 10" Nurburgring and it stuck out pretty far past the rim (which 315 Invos do not).
I believe 295 Michelins run just as wide or slightly wider than 315 Invos.
20inch, tires, tsw
