Old 03-29-2013, 09:12 PM   #15
Lio Martinez
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
I understand that the kit is set under 8PSI.. so its at 7PSI.... How much PSI can u increase the boost to so that gives more HP but is still safe ?
Lio Martinez is offline   Reply With Quote
Old 03-30-2013, 05:53 AM   #16
bob2010ss
bob2010ss's Avatar
Drives: Turbocharged 2010 GLOSSY NARDO GREY
are you speaking of the Turbonetics kit?
actually i believe that their test pulls on their video might be 8-9lbs
when we installed my kit, the techs at Turbonetics told us we could go 8lbs no problem maybe 9 without any issues, but it was my moooola$$$$$$$$$ and for the street as a DD 7 is enough in my opinion
[/SIGPIC]2010 2SS Turbonetics STAGE II 76 mm Single Top Mount
Bigger Pump, Bigger Injectors, No Cats, Gm Performance Cat Back CAMMED, METH and at 10lbs 630rwhp/ 690 ftlbs
SPI Built and Tuned
Eibach Suspension and beeeeeefed up axles!!!
and a whole lotta whooooooosh
oh and those are MT Drag Radials on the back
bob2010ss is offline   Reply With Quote
Old 03-30-2013, 07:05 AM   #17
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
You not going to be able to make big power out of the box without running into alot of back pressure.
JLE58 is offline   Reply With Quote
Old 03-30-2013, 11:09 AM   #18
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
I was hoping to find some one with a built motor pushing the psi up.
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 03-30-2013, 11:44 AM   #19
JLE58
Your not going to with the turbo that comes with it. Good turbo for a 600 Rwhp street car but a little small for a 376 inch motor to run alot of boost. I would imagine with the smaller turbine wheel it wouldn't make much over 10 psi on a ls3.
Old 03-30-2013, 11:54 AM   #20
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
I have the Turbonetics kit running 11 psi no problem. Do have some internal work done thought.
Sent from my iPhone using Tapatalk. If it is spelllled wrong, deal with it.
Crime2 is offline   Reply With Quote
Old 03-30-2013, 11:55 AM   #21
jasycz28
J.Sick
jasycz28's Avatar
dyno or track numbers??
"J.Sick"
2010 Camaro 2SS
Old 03-30-2013, 12:21 PM   #22
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Dyno- 714 rwhp on a Mustang dyno.
No track time yet. Still doing some tweaks.
Old 03-30-2013, 03:14 PM   #23
Lio Martinez
Yeah I was talking about the turbonetics kit... And since I want it for my only car which is my daily driver obviously my 2013 1LE I WANTED TO know how much boost was good and still safe
Old 03-30-2013, 05:06 PM   #24
bob2010ss
bob2010ss's Avatar
who is doing the install?
are you beefing up the fuel pump?
my advice also is to get a custom tune for the car!!!!!
like i mentioned earlier i drive my every day, it behaves like a stock car until i get heavy with the right foot, and at 7lbs it is an animal on the street!!!!
good luck!
SPI Built and Tuned
Old 03-30-2013, 05:31 PM   #25
stangkilr
stangkilr's Avatar
Drives: 2017 Camaro ZL1
I am blushing after reading this thread. lol. Thanks guys! To answer your question though I think that turbonetics kit is going to be maxed out at around 800-850 if you run E85, big fuel system and supporting mods on your engine (head studs, ls9 gaskets, turbo cam)
2017 ZL1
2014 Corvette
2002 Camaro
stangkilr is offline   Reply With Quote
Old 03-30-2013, 05:35 PM   #26
jasycz28
J.Sick
jasycz28's Avatar
Do you think the kit could go any further with a bigger turbo or would the piping size be the downfall?
"J.Sick"
2010 Camaro 2SS
Old 03-30-2013, 07:23 PM   #27
JLE58
I'm very Very surprise that the one guy made 715 with the kit on a mustang dyno. Surely it had some upgrades like a bigger down pipe atleast. Like I said I don't see this kit making much more than 10 psi with that smaller turbo I don't believe it would get close to 800 hp. At 715 the back pressure is prob through the roof. Upgrade the turbo and bigger down pipe when you buy it and your golden with some free flowing exhaust.
Old 03-30-2013, 11:04 PM   #28
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
I think you missed the part where I said "internal motor work also".
